Struts...???
Old Jul 10, 2006 | 09:40 PM
rleonekc's Avatar
Default Struts...???
Ok, i see struts for different prices ranging from 20$ to 200$
What is so good about the more expensive ones that the cheaper ones can't do?
Old Jul 10, 2006 | 10:16 PM
Dave_Darling's Avatar
Default Re: Struts...??? (rleonekc)
Lots of things.... The more expensive ones often are better built than the super-cheapies, so they tend to last longer. They also usually have had more attention paid to the actual shock valving, and an effort has been made to get valving that really works with a car's spring rate and weight and so on.
Finally, a lot of the higher-end shocks are adjustable. Either in rebound, or in both bump and rebound. That gives you a way of tweaking the car's handling to some extent, which is important when you're autoXing or on a road-course. Not so important when you're on the street, but then it can help you to fine-tune the car's ride/handling trade-off to where you like it.
--DD
Old Jul 10, 2006 | 10:23 PM
Smash03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rleonekc &raquo;</TD></TR><TR><TD CLASS="quote">Ok, i see struts for different prices ranging from 20$ to 200$
What is so good about the more expensive ones that the cheaper ones can't do?</TD></TR></TABLE>
What?....you've seen $20 shocks? Must be some really crappy ones.
Flava
Suspension & Brakes
19
May 18, 2006 11:02 AM
dmckrazy45
Jul 6, 2005 12:24 PM
AZNBIGPIMPN505
13
Jan 7, 2005 09:35 AM
caliprelude3087
Jan 4, 2005 03:03 AM
eg686
31
Jul 23, 2003 09:50 PM
