not sure whats goin on
Old Jul 10, 2006 | 08:33 PM
JDMPaulWall's Avatar
Default not sure whats goin on
Not sure whats goin on with my R. When I was driving today the car kept fluttering/cutting out then jumping rpms. I would go 5-10 mins fine then a min or two later it would studder and my tack would go crazy, new help asap !!??
Old Jul 10, 2006 | 08:41 PM
KayOs's Avatar
Default Re: not sure whats goin on (JDMPaulWall)
distributor or distributor internal components are beginning to fail.
Early signs of failure are sporadic bouncing of the tachometer needle.
or
check your cluster. Ensure all connections are tight.
Old Jul 10, 2006 | 08:42 PM
Default Re: not sure whats goin on (KayOs)
yea I was afraid of that, its a new distributor thats the thing. Any chance of it being loose wires leading to the distributor?
Old Jul 10, 2006 | 08:45 PM
KayOs's Avatar
Are the internal components new as well? (ignitor, coil)
OEM or aftermarket distributor?
Check all your engine grounds as well.
Old Jul 10, 2006 | 08:47 PM
yea all interal parts are new. I belive its oem, I just got it at my local advace auto.
Old Jul 10, 2006 | 08:49 PM
KayOs's Avatar
Its aftermarket if you bought it at Advance Auto. If you have access to a known working distributor from someone elses vehicle then that's how I would begin to isolate the problem. Good luck.
Old Jul 10, 2006 | 09:28 PM
noopsITR's Avatar
i had the same problem and thought it was the dizzy. couldnt figure it out so i took it to sportcar motion and they figured out it was the main engine ground wire was loose. but yeah, my needles were all over the place. paid $100 bucks for a tow just to find out it was something so simple.
Old Jul 12, 2006 | 08:31 PM
Default Re: (noopsITR)
alrite ill have to check that out. good lookin out
Old Jul 12, 2006 | 08:33 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noopsITR &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem and thought it was the dizzy. couldnt figure it out so i took it to sportcar motion and they figured out it was the main engine ground wire was loose. but yeah, my needles were all over the place. paid $100 bucks for a tow just to find out it was something so simple.</TD></TR></TABLE>
That would have been my 1st guess... but since you just touched the dizzy, go after that too.
Good luck..
Old Jul 13, 2006 | 01:03 PM
KayOs's Avatar
Let us know what the end result is/was.
Old Jul 13, 2006 | 01:24 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
I'd say ignitor, Mine did the same thing.
Old Jul 13, 2006 | 01:47 PM
Batoutahell's Avatar
I bought a new aftermarket distributor some time ago, and it quickly developed a loose wire. It's easy to wiggle the wires at the dizzy while the car is running to see if you can induce a hiccup. You might give that a try.
Old Jul 13, 2006 | 03:31 PM
Default Re: not sure whats goin on (Batoutahell)
The first time I took my car out it was fine for about 3hrs. then it began acting up soo I came home and took apart the dizzy to find that the screw that keeps the ignitor tight was out. After thinking I had fixed my problem I was able to drive around for another good 2hours. (trying to break in my new clutch as fast as possible) The next day I went for a second cruise and after a good 45mins it started to freak out again(studdering and tach going crazy). I checked my engine ground wire and it wasent bolted down to well. Im about to take another cruise now. So I am hoping that was the second answer to my problems. Any other thoughts on why the car will run fine for an hour or soo then freak out ??
Old Jul 13, 2006 | 04:32 PM
aight, that took about 2mins. The second I went to get on it alittle bit the car started to freak out and cont. Same ****, tack freaking out and miss firing
Old Jul 13, 2006 | 04:57 PM
Opie's Avatar
Distributor king is great and has awesome deals.
Old Jul 13, 2006 | 08:13 PM
Default Re: (Opie)
It is a new dizzy, I have gone through three already.
Old Jul 13, 2006 | 08:26 PM
Rcp's Avatar
Rcp
yup yup check the ground wire
Old Jul 13, 2006 | 08:29 PM
Mythias's Avatar
Go around the engine bay, and tq everything to spec. Do you have aftermarket mounts? Do you tq things down on a regular basis? It just seems like the vibration from the motor is rattling things loose. Break out that tq wrench and make sure its all within spec.
DRAGANDB1
Aug 9, 2018 06:19 PM
civic accord honda
Jul 27, 2009 06:08 PM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
93_teg_CT
May 28, 2006 11:26 AM
SIckH22Atch
Mar 31, 2003 09:12 AM
