JDM H22 Swap - A few problems!
Old Jul 10, 2006 | 06:18 PM
Maharajamd's Avatar
Default JDM H22 Swap - A few problems!
Well, me and 2 friends did a JDM swap last night. It works flawlessly other then a few problems. One, even if the car has been off for a long time, and you start it for 10 seconds, the radiator fan will be on afterwards for 10+ minutes. The other problem is the headlights don't work. Now, when I turn the headlight switch on, the gauge lights/etc come on, and they dim, but the headlights don't come on at all. Also the amber corner/parking lights work as well.
Prolly simple stupid fixes, just need to know because I wanna drive this thing! So quick answers would be great!
Old Jul 10, 2006 | 07:30 PM
soccmid1587's Avatar
Default Re: JDM H22 Swap - A few problems! (Maharajamd)
The radiator fan is due to the jdm h22a not having an ect switch A. I think anyways.
Do a search and you will find it no problem. As far as headlights id just check fuses and all your wiring connectors for them.
Old Jul 10, 2006 | 08:16 PM
SKDRCR's Avatar
Default Re: JDM H22 Swap - A few problems! (soccmid1587)
which wiring harness are you using,
if your using the h23 harness then use the
h23 housing with the temp switch on it,
that might fix your problem
Old Jul 10, 2006 | 08:45 PM
Maharajamd's Avatar
Default Re: JDM H22 Swap - A few problems! (SKDRCR)
We are usuing the h23 I believe. We just pulled the koyo radiator w/ h23 fans and put it back in. Dunno...
IntegraSpeedB18
Jul 26, 2008 07:57 AM
Entaka
Apr 20, 2006 02:05 AM
shutta
Nov 28, 2005 07:48 AM
hon-derr
Dec 27, 2004 06:13 PM
