sometimes car stalls out at idle.....how to fix this??
when i drive around it can be fine sometimes and cause problems at others.
when i drive on the highway and shift into neutral after about a second the car stalls(only sometimes).
same thing happens when i am at a light and shift into neutral(sometimes)
now this only happens sometimes because most ofo the time it will be perfectly fine.
i had a new thermostat put in and some head work done if that helps diagnose the problem at all.
you could also check the valve lash had the same problem after some head work and the valves were too tight
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtechlude »</TD></TR><TR><TD CLASS="quote">you could also check the valve lash had the same problem after some head work and the valves were too tight </TD></TR></TABLE>
i read somewhere how to check this,
.....most importantly and how can i fix this?
rig9896
Sep 16, 2003 07:53 PM
