car overheating bad! HELP!!
Old Jul 10, 2006 | 01:58 PM
reg4life's Avatar
Default car overheating bad! HELP!!
my car is overheating really bad. its a crx wit single cam turbo. wen i first start it up it sounds like its flooded too, engine sounds weird for about 5 minutes then sounds normal. after 10 minutes of driving the temp. gauge is at half way...the needle steadily increases and has touched the red. everytime i check the radiater its low on coolent. ive had to fill it up three times now. but its not leaking coolent at all.... i checked the spark plugs and the one in cylinder 3 is wet and darker looking then the rest. ive been told i mite hav a cracked head or a bad head gasket. nebody hav any other advise? im goin to be taking the head off today and checking the gasket and head for any bad signs.
Old Jul 10, 2006 | 02:18 PM
oneslowstd's Avatar
Default Re: car overheating bad! HELP!! (dc2_boy)
Do you have coolent in your oil???
Old Jul 10, 2006 | 02:23 PM
reg4life's Avatar
Default Re: car overheating bad! HELP!! (oneslowstd)
havnt draind the oil yet... so i dont kno
Old Jul 10, 2006 | 02:24 PM
oneslowstd's Avatar
are you blowing white smoke???
Old Jul 10, 2006 | 02:25 PM
oneslowstd's Avatar
Well if you check your dipstick, you will probaly find the oil to be milky colored but maybe not!
Old Jul 10, 2006 | 02:26 PM
ef 4 door's Avatar
also what do u mean....what type of noise?
as for the coolant check the engine coolant and oil dipstick
Old Jul 10, 2006 | 02:38 PM
zccr-xsi's Avatar
u do relize u cant reuse the old h/g right?so u just c ant pop it off look at it and put it back on.have u tried bleeding the system?when u say 3 cyl. is wet wet with what? gas, oil,coolant?
che'lu
Jan 27, 2008 06:01 AM
EF Driver
Jun 12, 2007 12:16 AM
bey
Jul 14, 2004 07:05 AM
GreenMachineRex
Mar 15, 2004 01:47 PM
Alpha_GSR
May 9, 2002 07:27 PM
