Sprint Springs question
Old Jul 10, 2006 | 12:45 PM
2-7offsuit's Avatar
Default Sprint Springs question
I just picked up some used ones. Two of the springs are wound the same all the way through (linear?) and the other two have part that's closer than the rest (progressive?). Which ones go in front and which go in back? This is for a '93 Si.
BTW- anyone have any experience with these? I'm going to be using them with some stock gsr struts. ?
Old Jul 10, 2006 | 04:21 PM
2-7offsuit's Avatar
So I think the progressively coiled ones go in the front. Can someone please confirm this?
Old Jul 12, 2006 | 12:59 PM
2-7offsuit's Avatar
Anyone?
Old Jul 12, 2006 | 01:02 PM
FalkenSiR's Avatar
Default Re: (2-7offsuit)
Longer ones go in the front.
Old Jul 12, 2006 | 01:22 PM
2-7offsuit's Avatar
They're the same length or damn close.
Old Jul 12, 2006 | 01:36 PM
EeeJayEight's Avatar
progressive in the front i think.. but not sure since i have never used progressive springs...
hmmm.. did you call sprint?
i always thought taht all the springs in a set were supposed to be progressive though.. maybe not..
Old Jul 12, 2006 | 01:37 PM
yecora's Avatar
Front springs usually has different diameter at top and bottom. Smaller size goes down, biger to up. Rear springs usually has same space between parts of springs, and same diameter in both ends. Any way, you couldn't mount rear springs at front fork becouse of different diameter.
Old Jul 12, 2006 | 01:41 PM
yecora's Avatar
Default Re: (yecora)
and i will recomend you to use famous manufacturer springs - like Eibach, H&R, Skunk, Tein, RSR, Espelir and so on. And do not use standart shoks with coilovers or lowering springs with big drop - you shocks will die very soon.
Old Jul 12, 2006 | 01:46 PM
i rode on stock shocks with ebay coilovers for like a year... luckily and i dont know my shocks didnt blow
but yea.. make sure you have something to support the more agressive spring rates
hatch_
Oct 11, 2006 08:04 AM
bo0sted
May 28, 2004 01:45 PM
Mychael1
Apr 27, 2002 07:48 AM
