whats needed to run itr front rear swaybars?
Old Jul 10, 2006 | 12:12 PM
01-0720's Avatar
Default whats needed to run itr front rear swaybars?
its a 94 dx i think
what whould my friend need to run oem type r front and rear sway bars
Old Jul 10, 2006 | 12:15 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: whats needed to run itr front rear swaybars? (01-0720)
the itr strut bars are bolt on.
Old Jul 10, 2006 | 12:18 PM
01-0720's Avatar
Default Re: whats needed to run itr front rear swaybars? (Rodney)
even on a base model, he doesnt need any kind of endlinks or anything?
Old Jul 10, 2006 | 12:19 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">its a 94 dx i think
what whould my friend need to run oem type r front and rear strut bars</TD></TR></TABLE>
Assuming you are talking about SWAY-bars, and not strut tower bars, you will need:
ITR front swaybar
ITR front swaybar bushings, D-brackets and related nuts and bolts
OEM GSR Endlinks and hardware
SI or GSR front LCA's with swaybar holes.
I dont know part numbers, but for a small fee, I can find out!
Edit: GSR and ITR front swaybars are the same... 24mm.
Old Jul 10, 2006 | 12:20 PM
01-0720's Avatar
Default Re: whats needed to run itr front rear swaybars? (JDM_Ej)
yeah def meant swaybars
Old Jul 10, 2006 | 12:34 PM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">yeah def meant swaybars</TD></TR></TABLE>
ah, i see you edited your orig post. for the rear you will need a mount kit. no need to put one on the front. itr front bar is not needed.
Old Jul 10, 2006 | 12:47 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
Edit: GSR and ITR front swaybars are the same... 24mm. </TD></TR></TABLE>
But shaped differently. You need differently endlinks depending on which sway bar you're going to get.
For rear sway... I recommend in investing in an ASR subframe brace to prevent subframe tearout and it looks cool from behind. Then you'll need LCAs with holes in them from an Integra or go aftermarket. You'll need brackets, bushings, endlinks, and bolts.
Old Jul 10, 2006 | 12:52 PM
instructor74's Avatar
Default Re: whats needed to run itr front rear swaybars? (BlueIntegraBoy)
Also if the car didn't have a front sway bar you will need the left and right lower front control arms
Emerica
Nov 9, 2007 09:35 AM
GsR-Freak
Jan 17, 2005 06:18 AM
Outkasted24
Dec 20, 2004 02:34 AM
Transport
10
May 12, 2004 07:04 PM
Transport
May 11, 2004 12:19 PM
