Please let me know what happen
Old Jul 10, 2006 | 08:47 AM
BIGNIKO's Avatar
Default Please let me know what happen
i missed 2nd gear and my car shut off then i try to start it back up but theres no power no cluster lights come on and i cant crank over motor.
ALSo i pulled my intake off and inside throttle body there was oil and antifreeze. WHY ?
ALSO TRYED JUMP STARTING THE CAR STILL NO POWER
HELP!!!!!!!!!!
Old Jul 10, 2006 | 08:52 AM
Wannabe JDM's Avatar
well if you got oil and antifreeze in you TB then I would say you blew your head gasket. Or possibly broke something a little more costly.
Were you getting on it when you missed 2nd?
Old Jul 10, 2006 | 08:55 AM
BIGNIKO's Avatar
Default Re: Please let me know what happen (BIGNIKO)
yeah got no revlimiter on my computer so i over revd
Old Jul 10, 2006 | 08:56 AM
What motor do you have and about how high did you rev it?
Old Jul 10, 2006 | 08:57 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
I'm willing to bet you blew a nice hole in a piston, or crushed valves.
Do a compression test.
Old Jul 10, 2006 | 08:58 AM
prison_snitch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGNIKO &raquo;</TD></TR><TR><TD CLASS="quote">yeah got no revlimiter on my computer so i over revd </TD></TR></TABLE>
you're an idiot... unless you got a fully built motor(which you dont) why would you remove your limiter? even with a fully built motor you would keep it at like 9k or whatever your **** go up to
Old Jul 10, 2006 | 09:00 AM
ehh give him a break. He pulled his rev limiter and he made a mistake. Im guessing he learned his lesson. No need for flaming.
Old Jul 10, 2006 | 09:01 AM
Default Re: Please let me know what happen (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">I'm willing to bet you blew a nice hole in a piston, or crushed valves.
Do a compression test. </TD></TR></TABLE>
like I said...possibly something more expensive.
Old Jul 10, 2006 | 09:03 AM
BIGNIKO's Avatar
cant do a compression test cause my motor wont crank over cause im getting no power
Old Jul 10, 2006 | 09:07 AM
cockerkid008's Avatar
you dont need to get the starter to crank it over you crank it over with a wrench
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGNIKO &raquo;</TD></TR><TR><TD CLASS="quote">cant do a compression test cause my motor wont crank over cause im getting no power i dont know what happen with having no lights coming on dash</TD></TR></TABLE>
Have you checked all the grounds and the battery? The battery terminals could have come loose.
Old Jul 10, 2006 | 09:08 AM
BIGNIKO's Avatar
Default Re: (slowej)
def revd motor over 9k i bought swap with p28 no chip oh yeah its a gsr
Old Jul 10, 2006 | 09:09 AM
instructor74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGNIKO &raquo;</TD></TR><TR><TD CLASS="quote">cant do a compression test cause my motor wont crank over cause im getting no power i don't know what happen with having no lights coming on dash</TD></TR></TABLE>
Its time to pull the head off and see what you bent and what got broken I am willing to bet that you bent a piston rod and the motor is locked up because of that. Along with other valve train damage
Old Jul 10, 2006 | 09:10 AM
BIGNIKO's Avatar
Default Re: Please let me know what happen (SOHC4life 96)
yeah i would like to solve my eletrical problem other then having to spin crank with a wrench
Old Jul 10, 2006 | 09:24 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGNIKO &raquo;</TD></TR><TR><TD CLASS="quote">yeah i would like to solve my eletrical problem other then having to spin crank with a wrench</TD></TR></TABLE>
Connect a working battery. Check fuses.
DO COMPRESSION TEST
Old Jul 10, 2006 | 09:32 AM
Archidictus's Avatar
Unceasing Measure
You destroyed your motor: why do you need to do a compression test? Pull the spark plugs and put somethig long and thin into the holes and see if all four pistons are still where they should be. I'm betting at least one of them is not. Pull your head too, because at the very least you're going to have 8 or so bent valves.
MRturbo
Dec 27, 2007 04:16 PM
Global688
Nov 27, 2007 05:27 AM
lude of pre 2.3
Jul 1, 2005 01:03 PM
OpTiX619
Jan 29, 2004 01:10 PM
pagong
Jun 27, 2001 08:43 AM
