searched: tranny question
Old Jul 10, 2006 | 06:01 AM
seifer's Avatar
Default searched: tranny question
Vehicule: 98 GSR usdm
Hi there,
My mecano/friend repaired my head (a valve messed up) in my head and we did a full tune up at the same time and he put normal 10w/30 engine oil in my tranny which I found odd but was told by 2-3 guys it was fine.
Its now been a month and my first/second gears are starting to rattle at low rpm and so does the 5th sometimes when rolling. When not in gear it rattles a little and when I clutch it completely stops.
I bought 2 paints of genuine honda transmission oil and will change it but Im wondering how extensive the damage can be. Before that my tranny was flawless and Im now wondering how much labor it costs the rebuild a tranny. Im also thinking about getting a TypeR tranny if I get a good deal.
Lemme know what you all think, any advice is appreciated.
Thanks
Old Jul 10, 2006 | 07:22 AM
Lan's Avatar
Lan
Default Re: searched: tranny question (seifer)
Does it vibrate or make noise?
Old Jul 10, 2006 | 07:49 AM
seifer's Avatar
Default Re: searched: tranny question (Lan)
It doesn't vibrate as far as I can tell but it does make a rattling noise when starting on the first gear and when I gear the 2nd one (when I push the gas after its geared).
Its as if it took 2 years of age in a month!
Old Jul 10, 2006 | 07:55 AM
Lan's Avatar
Lan
Using that weight oil in your tranny for a month will not cause internal damage unless the parts were worn to begin with. I would recommend you IM Bense. He seems to be the tranny expert on this site
Old Jul 10, 2006 | 08:34 AM
Bense's Avatar
normal 10w-30 is fine to use I can't think of what happened. try cahging the fluid out with honda MTF. Also, don't b-series require 2.5 qts? i'm not sure
Old Jul 10, 2006 | 11:42 AM
lVlemphizStylez's Avatar
Default Re: searched: tranny question (Bense)
they use like 2.2
civic-rice-rockit
15
Feb 19, 2009 02:19 PM
LostSolVTEC
Mar 8, 2004 10:23 AM
It's Blue
Oct 13, 2002 06:51 PM
