CIVIC siR 2 COLD AIR INTAKE
Old Jul 10, 2006 | 04:53 AM
sir222's Avatar
Default CIVIC siR 2 COLD AIR INTAKE
hey everyone, im quite new with the hondas but i am in the process of importing a civic eg6 siR 2 from japan. i really want to buy a full cold air intake that can be changed between full cold air intake and a short ram intake for different weather conditions, but i cant seem to find one for the siR/vti only an SI or DX etc which i havent even heard of.
please give me some help people!??
cheers josh
Old Jul 10, 2006 | 05:37 AM
cambopheonix56's Avatar
Default Re: CIVIC siR 2 COLD AIR INTAKE (sir222)
Buy an injen sri and then purchase a injen cold air intake extension.
Old Jul 10, 2006 | 10:28 AM
sir222's Avatar
Default Re: CIVIC siR 2 COLD AIR INTAKE (cambopheonix56)
hi thanks for the reply, i have been looking around on the net and i have found the intake extension, but its only available for the nissan.... and the SRI i take stands for short ram intake... i can get one of those for my car i think.
cheers josh
Old Jul 10, 2006 | 10:33 AM
should be the same as the em1 i think.
Old Jul 10, 2006 | 11:06 AM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">should be the same as the em1 i think.</TD></TR></TABLE>
unless it has abs, but you can always buya 1 piece and cut it and get an extra coupling and two clmps. also check ebay the cheap ones are usually 2 piece just invest in a decent filter.
Old Jul 10, 2006 | 11:20 AM
sir222's Avatar
Default Re: CIVIC siR 2 COLD AIR INTAKE (JSPECSIR)
thanks mate......yes it has got ABS.
so you think it will be okay to buy the INJEN short ram intake, and the extension, but then maybe have to cut the extension?
i have found the cheap ones on ebay now, but i wonder... do the cheaper ones not increase the performance so much????
thanks for your help!! sorry if im being bumb!
Modified by sir222 at 12:42 PM 7/10/2006
Old Jul 10, 2006 | 01:18 PM
There is not much of a difference between eBay intakes and Injens. You might see 2 more peak power. They actually make more power down low.
Old Jul 10, 2006 | 04:42 PM
JSPECSIR's Avatar
as far as a difference, pipe is pipe(not pvc, or dryerhose.... I know what you smart asses are thinking. ), unless its coated with something or is a different diameter or what not. just compare pics, size and bends, and do your homework, youll get a decent intake. if you have abs you might need to research if you need to buy an integra w/abs intake. my car is a 94 si, with a sir motor, i ued a 99-00 civic si cold air intake(2.5" diam.), and ive used a 92-95 ex/si short ram(3" diam.), both with excellent results( i dont have abs though, but it is possible your abs box isnt in the way.... like i said research) it'll work out.
Old Jul 10, 2006 | 05:55 PM
LuCkYcOuPe's Avatar
J's Racing intake for the B16
RedlineMotive
15
Oct 7, 2009 10:22 AM
Cannuck 94
16
Dec 30, 2005 11:30 AM
Lostmike23
Mar 29, 2004 05:08 PM
1 Special CTR
Oct 26, 2002 12:28 PM
SL1D3R
Jul 15, 2001 11:05 PM
