Need ECU diagram for 99 ls auto
Old Apr 19, 2002 | 07:18 PM
shadowdawn's Avatar
Default Need ECU diagram for 99 ls auto
Anyone know where I can located a complete specific diagram for a 99 LS automatic 2dr ecu? I have an s-afc but don't trust the manual's wiring diagrams as most people are saying they are wack, and I really don't wanna wire this stuff into the wrong wire etc... or if anyone has installed a safc in a 98+ integra ls/gs please provide any info you can. I'm going to try to tackle the install tomorrow.
Old Apr 19, 2002 | 09:49 PM
PrecisionH23a's Avatar
Default Re: Need ECU diagram for 99 ls auto (shadowdawn)
Why would you not trust a wiring manual from apexi? A friend of mine installed a s-afc on his LS a few weeks ago and went by the manual apexi sent and it worked fine. Apexi would not give out a "wack" wiring diagram to play a joke on people. If there was something wrong with the manual im sure they would have fixed this problem by now. Go to the site below, it has a s-afc wiring update (so if anything was wrong before, now its right ).
http://www.apexi-usa.com/documentation.asp
As long as you can read the diagram correctly you should not have any problems hooking this up, it is very straight forward. good luck
blackdc
Jan 12, 2004 11:41 AM
LS stretch
Oct 30, 2003 04:56 PM
Jamison
May 28, 2002 01:55 PM
shadowdawn
Apr 18, 2002 01:41 PM
Superesc
Mar 23, 2002 09:28 PM
