HELP!! Squeaking noise and car shaking.. problem??
Old Jul 9, 2006 | 10:49 PM
01 itr dc2's Avatar
Default HELP!! Squeaking noise and car shaking.. problem??
i need your guys' input. in 2nd or 3rd wen im at 3k n let the rpm drop, there is a squaking noise sounds like its coming from the drivers front wheel area. it sounds like its going around as the wheel turns because as i slow down, so does the squaking. also on the freeway or at high speeds, the car tends to shake a little, im prety sure its from the same thing. im thinking its an axle or a wheel bearing, have any of you had this problem or know what is wrong with it? thanks.
Old Jul 9, 2006 | 10:56 PM
gamemaster000's Avatar
Default Re: HELP!! Squeaking noise and car shaking.. problem?? (01 itr dc2)
My LS was doing something very similar, ended up being the bearing. Not saying that is what your is, but it sounds like a similar problem.
I was getting my brakes/rotors done anyway, so I had them throw in a new bearing as well.
Old Jul 10, 2006 | 11:00 AM
01 itr dc2's Avatar
Default Re: HELP!! Squeaking noise and car shaking.. problem?? (gamemaster000)
ok thanks ill get it checked out. do you know how much a new bearing will cost?
Old Jul 10, 2006 | 11:08 AM
I think it was around $95 for the new parts, then add what ever labor will be. I think my shop charged for an hour.
Old Jul 10, 2006 | 11:09 AM
01 itr dc2's Avatar
ok thanks.
Old Jul 13, 2006 | 11:18 AM
01 itr dc2's Avatar
so i took it into the shop and they told me what was wrong with it, both front axles were torn and ripped so i am getting them replaced. for future, does lowering the car extremely put stress on the axles and tend them rip/tear easier or was it somtething else?
Old Jul 14, 2006 | 01:48 AM
01 itr dc2's Avatar
bump
tcsubaru
Jan 11, 2012 09:49 AM
rice a roni
Nov 27, 2008 05:08 AM
spender1326
May 31, 2005 05:27 PM
eg6turb0
May 10, 2005 01:41 PM
NWPNOMORE
Jun 20, 2002 10:22 PM
