My next mod from here.... ???
Old Jul 9, 2006 | 10:07 PM
tekcivic's Avatar
Default My next mod from here.... ???
Hi all! This is my first post to the forum. I hope I can get the help I need. I have two civics, one of which I've been working on for a while now. This will be mainly a show car, however I have the engine slightly moded and would like to take it just a bit further.
More information about the car:
Model
94 Civic EX
Engine
D16Z6 1.6L V-Tec
Mods
Ram air intake
header
exhaust
stage 2 clutch
The nitty gritty....
What would be the best mod to do from this point? I don't want to race this car just give it a little more umph if you know what I mean. I was thinking of switching to the cold air intake as aposed to the ram air. I noticed when the car is cold (first start of the day) the air it is sucking in is much cooler and makes the car perform better at low rpms. I was also thinking of putting in a lighter flywheel, I notice a bit of a problem when shifting from 1st to 2nd at high rpms, would a lighter flywheel take care of this? After that where do I go? Cams? cam gears? injectors? just not sure what. I know quite a bit about body work but hardly nothing of engine work.
All help is greatly appreciated!
Tek
Old Jul 9, 2006 | 10:10 PM
Sa.L.aS's Avatar
Carpe diem!
Default Re: My next mod from here.... ??? (tekcivic)
motor swap
Old Jul 9, 2006 | 10:21 PM
Jason-'s Avatar
LMAO.
Just turbo it. 6-7psi and get it tuned. Afterall, singles are a dime a dozen. Or just swap it for a big boy.
-Jason
Old Jul 9, 2006 | 10:25 PM
Ls_V_TurboSi's Avatar
Default Re: (Jason-)
the only way you'll get any noticable power is a swap or turbo.. Any money you dump into for basic bolts ons is pretty much a waste
Old Jul 9, 2006 | 10:52 PM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default Re: (Ls_V_TurboSi)
pm'd
Old Jul 9, 2006 | 11:16 PM
fms1day's Avatar
Default Re: (Evolution-93-Ex)
d16z6-t
Old Jul 9, 2006 | 11:50 PM
tekcivic's Avatar
LOL I'm sorry I thought people on here might know what they are talking about. If you read the post carefully I dont want to race this car.... I have another civic with an h22a I'm going to bore and turbo.....
I just wanted to get another 20 to 40 horses out of this d16....
Old Jul 9, 2006 | 11:54 PM
SovXietday's Avatar
Default Re: (tekcivic)
IM + TB
PnP + Cams
Chip + Tune
Simple really.
Old Jul 9, 2006 | 11:59 PM
tekcivic's Avatar
thank you sovxetday.... exactly the type of answer I was looking for.... not to just slap a turbo on it, LOL.
Old Jul 10, 2006 | 12:33 AM
jboy08's Avatar
SUSPENSION
Old Jul 10, 2006 | 12:35 AM
tekcivic's Avatar
Default Re: (jboy08)
yea suspension has also been modified with nuspeed springs (total of 2 1/4" drop) I also plan on adding air ride because I can't even go over a speedbump after having added the body kit.
Old Jul 10, 2006 | 12:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekcivic &raquo;</TD></TR><TR><TD CLASS="quote">thank you sovxetday.... exactly the type of answer I was looking for.... not to just slap a turbo on it, LOL.</TD></TR></TABLE>
The thing is, You'll be spending ALOT of money on parts that are gonna give you pretty much no gain. Your best bet is to get out of that d-series into a b or turbo it.. You can peice together a kit pretty cheap
Either way good luck with your gaol
Old Jul 10, 2006 | 01:07 AM
tekcivic's Avatar
Understood.... however doing these things will give me the 20 to 40 horses I'm looking for and I'm sure will all together be cheaping than doing something like a turbo...
Again I already have another civic with a Prelude H22a inside that I am modding out and stripping down for the race track. This civic with the D16 I have spent waaayyy too much time on the body work to be worried about making it race worthy. I just want a little more go on the green light.
Tek
Old Jul 10, 2006 | 11:20 AM
DB1_559's Avatar
GOT A JUN FLYWHEEL FOR U HOLLA AT ME
Old Jul 10, 2006 | 11:56 AM
jdm b18c ek4's Avatar
port and polish head, cams, cam gears, manifold, bore and hone the block, theres alot of internals things u can do, chipped ecu + tunning
Old Jul 10, 2006 | 12:36 PM
Wannabe JDM's Avatar
NAWZ
if your looking for a cheap way to get 20-40hp then nitrous is the way to go.
Old Jul 10, 2006 | 12:48 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (slowej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowej &raquo;</TD></TR><TR><TD CLASS="quote">NAWZ
if your looking for a cheap way to get 20-40hp then nitrous is the way to go. </TD></TR></TABLE>
Cheapest way.
To get 20-40hp out of a Z6, you will be spending the same amount if you were to get a swap.
HarleyJones
Honda Civic (2001 - 2005)
Jun 8, 2015 10:03 PM
HunterL1990
24
Feb 4, 2015 03:47 PM
Greyhead
Honda CR-V & Element
Mar 18, 2014 05:35 PM
u_hsen
Honda Civic (2006 - 2015)
16
May 13, 2007 10:23 AM
io_burn
Aug 27, 2001 09:36 PM
