Best Wires and Plugs
Old Jul 9, 2006 | 08:06 PM
bbhockey19's Avatar
Default Best Wires and Plugs
I have a 99 Ex and i want to gain some more Hp's with adding some Nology Wires and some NGK plugs are these the 2 brands that will add me the most Horsepower.
Old Jul 9, 2006 | 08:08 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Best Wires and Plugs (bbhockey19)
i.m.h.o. nology = garbage.
i did msd, but ihave everything msd, on my customer cars, i use NGK top and bottom.
Old Jul 9, 2006 | 08:13 PM
Syndacate's Avatar
use NGK plugs and Bosch wires
Really good of both
You won't see any hp increases by putting in super spark plugs
Old Jul 9, 2006 | 08:17 PM
hapexamendios 2.0's Avatar
R.I.P.
no plugs or wires is going to make a HP gain in your stock engine
Old Jul 10, 2006 | 04:00 AM
ek9-b18cr's Avatar
I would prefer OEM but it does matter on what your plans are for your EX.
Are you going for show, JDM accesories, or race?
IMO just go with NGK plugs and wires or even Denso.
If Youre going with a whole ignition system, then you might want to go with MSD, such as wires, dist. cap, ignition system, etc.......$.02
Old Jul 10, 2006 | 04:06 AM
Ricey McRicerton's Avatar
Default Re: Best Wires and Plugs (honda 3300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda 3300 &raquo;</TD></TR><TR><TD CLASS="quote">no plugs or wires is going to make a HP gain in your stock engine</TD></TR></TABLE>
Word.
Stock wires because they don't pop off, and I use NGK plugs, 1 step colder for my turbo setup.
Old Jul 11, 2006 | 06:11 PM
bbhockey19's Avatar
I have AEM Short Ram, Greddy Headers, and Skunk 2 catback what wires and plugs will be the best
Old Jul 11, 2006 | 06:15 PM
R.I.P.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbhockey19 &raquo;</TD></TR><TR><TD CLASS="quote">I have AEM Short Ram, Greddy Headers, and Skunk 2 catback what wires and plugs will be the best</TD></TR></TABLE>didnt you read any of that? none are gonna give you more horse power, just stick with OEM
Old Jul 12, 2006 | 06:28 AM
Syndacate's Avatar
NGK's for rice burners IMO
Definately, I put NGK's in all 4 bangers and have never had a problem
Old Jul 12, 2006 | 06:32 AM
sicky's Avatar
grammer nawzi
Bet you're making mad whp in your car. Not to be a dick, but you will learn that the money you dropped on those parts was useless.
On the wires/plugs issue: stay stock, you don't see any whp gain with wires. And with your F&F mods, stay oem.
Old Jul 12, 2006 | 07:37 AM
-Gary-'s Avatar
Default Re: Best Wires and Plugs (sicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">
On the wires/plugs issue: stay stock, you don't see any whp gain with wires. And with your F&F mods, stay oem.</TD></TR></TABLE>
He may not have siad it the nicest way, but he's right. Stock plugs and wires should work just fine.
Old Jul 12, 2006 | 07:42 AM
LowSlow93Sol's Avatar
Default Re: Best Wires and Plugs (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- &raquo;</TD></TR><TR><TD CLASS="quote">
He may not have siad it the nicest way, but he's right. Stock plugs and wires should work just fine. </TD></TR></TABLE>
Save your money and get a part that will actually increase HP.
Old Jul 12, 2006 | 08:09 AM
sinister6's Avatar
Default Re: Best Wires and Plugs (onefast93sol)
For Plugs I use nothing but NGK, Denso and other Denso OEM plugs tip tend to fall/drop when get too hot. i didnt experienced this but there are a couple people I know happened to them. it might be a single case but still.
Again, this only apply to heavily mod engines.
For a stock like yours, i would say just get NGK platinums. they works great and last way longer than every Ir. plugs. even NGK's own Ir.X
Im with the VX in daily driven and changed to Ir.x 8 in track when it keeps hitting 9500rpm.
Old Jul 12, 2006 | 09:52 AM
O RLY's Avatar
Default Re: Best Wires and Plugs (sinister6)
NGK plug wires and NGK Iridiums. Stay away from Bosch and Denso IMO. The plug wires mad eby NGK are just a good replacement, nothing more. People are totally misled, when they try to add HP by modding the ignition components. Even MSD SCI modules and Blaster Coils are pretty much uneccessary since most Hondas make 650 whp on stock ignition components. I'd say go internals, but building a head would be more down time, and a lot more money.
Old Jul 12, 2006 | 10:45 AM
4potnick's Avatar
Default Re: Best Wires and Plugs (O RLY)
I always use ngk plugas and wires in all hondas. If you car is daily driven more the likely oem/ngk are more than capable of the task. N/a or boosted.
Old Jul 12, 2006 | 10:54 AM
suspendedHatch's Avatar
Default Re: Best Wires and Plugs (4potnick)
Magnecor are actually the best on the market. They're worth the cost because you never have to replace them. They are more benefits to them, but it doesn't apply to you unless you have a sensitive audio system or you have a sensitive programmable ECU or datalogger. Very overkill, but like I said, they last forever so they eventually pay for themselves.
OEM are okay, NGK are better. Everything else is questionable at best.
You don't need to upgrade the factory ignition system unless you increase compression a great deal or if you are running forced induction. Most aftermarket ignition components are actually worse than stock. Nology is one of them.
Old Jul 12, 2006 | 11:05 AM
-Gambit-'s Avatar
Default Re: (Syndacate)
i use ngk
Old Jul 12, 2006 | 11:36 AM
b00st Junkie's Avatar
TOASTYYY!!
Default Re: Best Wires and Plugs (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Magnecor are actually the best on the market. They're worth the cost because you never have to replace them. They are more benefits to them, but it doesn't apply to you unless you have a sensitive audio system or you have a sensitive programmable ECU or datalogger. Very overkill, but like I said, they last forever so they eventually pay for themselves.
You don't need to upgrade the factory ignition system unless you increase compression a great deal or if you are running forced induction. Most aftermarket ignition components are actually worse than stock. Nology is one of them.</TD></TR></TABLE>
+1
Tytank7
Feb 12, 2008 06:16 PM
indy_93accordex
Feb 26, 2004 11:42 AM
Got Spoool
26
Jun 13, 2003 03:06 PM
CBR600OnTop
Feb 15, 2003 10:35 PM
cccya
Jul 16, 2002 11:21 AM
