What do you think of this integra engine build LSvtec?
Old Jul 9, 2006 | 07:00 PM
ranciddd's Avatar
Default What do you think of this integra engine build LSvtec?
ls/vtec include stock ls block jdm b16 head, ctr cams,
si valve springs/retainers, arp head stud, itr manifold with throotle body with direct port set up, 4-1 itr header with tanabe full cat back(ultralight titanium), short gear si-r tranny with the spoon lsd, jun ultralite chromoly flywheel,act stage 3 pressure plate/clutch, jdm wrinkle red valve cover, obd2 to obd1 harness with reprogramed p30
Im asking bc i plan on buying a car w this lsvtec setup. Is it a good setup? Thank you for your input.
Old Jul 9, 2006 | 07:04 PM
94_DC4's Avatar
Default Re: What do you think of this integra engine build LSvtec? (ranciddd)
Always be careful when buying a used modified car. Sounds like a good set up but then again you dont know the kind of abuse, if any, it has been subjected to.
Old Jul 9, 2006 | 07:06 PM
Backk InTheDA's Avatar
I hate everything
Default Re: What do you think of this integra engine build LSvtec? (SiRGDC)
That actually sounds really nice, but to reiderate what sirgdc said. Becareful when buying a used modified car. A) You don't know if it was done correctly, like reliability issues, and B) It could be on its last limb.
93_teg_CT's Avatar
Jdm wrinkle red valve cover makes it worth it. I say go for it!
Old Jul 9, 2006 | 07:09 PM
I hate everything
Default Re: What do you think of this integra engine build LSvtec? (93_teg_CT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_teg_CT &raquo;</TD></TR><TR><TD CLASS="quote">Jdm wrinkle red valve cover makes it worth it. I say go for it!</TD></TR></TABLE>
Hey, I'm getting one for ls/vtec built
Old Jul 9, 2006 | 07:50 PM
ranciddd's Avatar
i know he got his work done by a professional shop but yea just dont know if its on its last limb he said its has 43k on the engine the body has 100k
Old Jul 9, 2006 | 07:57 PM
Spectrum24x's Avatar
If its survived 43k and was done by a professional shop, its not on its last limb, its got many miles to go..
First off, what year and model car, and how much? Some people overprice there Ls/V's
Also, it sounds like a good setup to me, its prolly making around 180whp or so, remember someone will always be faster then you.
Old Jul 10, 2006 | 01:24 PM
ranciddd's Avatar
Default Re: What do you think of this integra engine build LSvtec? (Spectrum24x)
its a 97 gsr with about 114000 on the body and 45k on the engine
Old Jul 10, 2006 | 02:30 PM
buppy's Avatar
Hey, u r doing the right thing definitly..........I just bought a 1997 Integra Ls and i am either putting on a b16, b18 C1, or a b18 C5,..........I dont no which one to put on..........what do u think...........thanks
Old Jul 10, 2006 | 03:08 PM
Sic_DA_Nine's Avatar
cant really tell if its about to die or not
go check it out....check the oil, look for leaks, any cut harnesses/hoses
start the car and see if any awkward sounds, and if its smoking....
it doesnt matter if it was done by a professional...
he coulda messed it up within those 45k miles
good luck...and hopefully its not junk
elbeanerhatch
Feb 14, 2008 01:19 PM
.:Made in OC:.
Feb 24, 2007 08:41 AM
g2lsvtec
12
May 13, 2006 04:02 PM
2ndgent3g
10
Jun 6, 2005 06:36 PM
Civichatch2k
Nov 18, 2002 06:38 PM
