Motor 90 DX is bogging..
Wsup Peeps,
I need some help, when driving my 90 DX sedan it bogs. When you drive it regular around the streets it's fine. However when you give it gas suddenly it starts to jerk like there is no air coming in. It also does that on the freeway, sometimes the car will turn off when driving it.
I change to fuel filter already but it did not solve the problem. Can anyone help me with this problem?
In order to pick up speed, you will need to accelerate gradually and if you gun the car it will choke like hell and it will turn off.
Please help....
Please help....
had the very same problem with my 90 crx HF with a sohc zc swap.... figured out it was bad fuel injectors... they would basically be cutting in and out... i tried to use fuel injector cleaner but i just went and got a pair of used injectors for cheap
efras
Apr 12, 2008 03:00 PM
EJ2-Fluffy
Oct 4, 2003 01:00 AM
EJ2-Fluffy
Aug 16, 2003 05:49 PM
