Are all B-series Rod and Main bearings the same ???
are b16, b17, b18, b20 rod and main bearings interchangeable ???(from engine to engine not rod to main)
are they different from V-tec to non V-tec ???
tryed several searches and found nothing on this topic
No, some of the bearings are different. For example, b18a rod bearings are different from b18c rod bearings. Bearings also come in various thicknesses depending on application etc. For example, you can have two b18a blocks, but they might require different thickness bearings depending on clearances.
