I'm running on 3 cylinders, why?
Old Jul 9, 2006 | 03:38 PM
fast_honda's Avatar
Default Running on 3 Cylinders, still no conclusion
Just swapped in a jdm h22a last weekend, it has a new dizzy, cap, rotor, msd wires, ngk plugs, pcv valve, good compression on all 4 cylinders, but my #1 isn't running. The plugs are getting spark, I can hear the injector working, so it may be an air issue. My car is missing an Intake Control Silenoid Valve, and is missing the module that runs the flapper diaphram (which shouldn't effect anything right?) The engine doesn't idle very well and sometimes dies. I'm almost tempted to see if a rag got sucked into the #1 intake plenum when the shop hooked it up, that's how confuzed I am.
Modified by fast_honda at 6:07 PM 7/9/2006
Modified by fast_honda at 6:18 PM 7/9/2006
Old Jul 9, 2006 | 04:26 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: I'm running on 3 cylinders, why? (fast_honda)
wierd could be bad wires??? did you take out the pluig??/ take it out swap all 4....compare the t plugs....could be somethin simple......and if you did suck something in the tip of the plug would look smashed...
Old Jul 9, 2006 | 05:01 PM
fast_honda's Avatar
Default Re: I'm running on 3 cylinders, why? (I got the CD5 Jeebies!)
They're new wires and plugs and are getting spark. When I took the new plugs out I noted that they were blackened, is that from lack of fuel?
Old Jul 9, 2006 | 05:20 PM
VTECnKEN's Avatar
You can get good comp. and leak specs, but the valvetrain could still be at fault. Open the head and check for broken rocker arms on #1.
edit: about yor spark plugs, when they're fouled like that, your air/fuel mixture is too rich.
Old Jul 9, 2006 | 05:24 PM
yOnKiNaToR's Avatar
Default Re: I'm running on 3 cylinders, why? (VTECnKEN)
clogged injector? try switching around the injectors. if a different cylinder doesn't fire, you know that injector isn't working.
Old Jul 9, 2006 | 07:20 PM
fast_honda's Avatar
Default Re: I'm running on 3 cylinders, why? (yOnKiNaToR)
I tested the injectors yesterday by unplugging them while the engine was running. Cylinder #1 was uneffected when I unplugged the injector, the idle changed for the rest of the cylinders when they were unplugged. So I replaced the stock injector for a 240cc from my H23 but it didn't change a thing, maybe the test injector was clogged, or my wiring is bad. I also checked my rockers and saw nothing unusual.
Modified by fast_honda at 9:11 PM 7/9/2006
Old Jul 11, 2006 | 05:41 AM
fast_honda's Avatar
Default Re: Running on 3 Cylinders, still no conclusion (fast_honda)
would a bad MAP sensor or IACV cause the engine to misfire like this? This is serious I really need to fix this thing, I get bad gas milage but more importantly I can't enjoy my VTEC like I want to.
Modified by fast_honda at 10:14 PM 7/11/2006
Old Jul 12, 2006 | 12:49 PM
fast_honda's Avatar
It was a bad ECU and it didn't flash a CEL 1 or anything, no wonder I was so confused, it runs perfect now with the new P13.
Modified by fast_honda at 8:40 PM 7/12/2006
Old Jul 12, 2006 | 04:53 PM
god ****..after all my pondering I would of neve thought it was the ECU
Old Jul 12, 2006 | 05:54 PM
VTECnKEN's Avatar
Default Re: Running on 3 Cylinders, still no conclusion (I got the CD5 Jeebies!)
lol, f*cking ECU.
Out of everything that could break on a car, you never expect the digital aspects like an ECU to fail
Glad you found the problem and I'm sure you're enjoying your ride a lot more now!
Lewsears
Mar 20, 2010 09:25 AM
b16b18
Sep 6, 2006 12:56 PM
whoobeedoobee
Aug 6, 2003 05:03 PM
SSBlueDC2
Feb 7, 2003 07:45 PM
hondacivic4g
Jul 11, 2002 04:22 PM
