main relay
Old Jul 9, 2006 | 02:06 PM
6doorsentra's Avatar
Default main relay
How can I check to see if the main fuse relay is ok? The fuse relay that is near the fuse box with a 10mm bolt holding it up.
Thanks
Old Jul 9, 2006 | 02:45 PM
Backk InTheDA's Avatar
I hate everything
Default Re: main relay (6doorsentra)
Well, its good if your car starts up and doesn't die immediately in hot weather. It's bad, if it in hot weather, the car starts up, and dies right away.
What year is your integra?
Old Jul 10, 2006 | 09:10 AM
95 integra. The car will sometimes get a check engine light. I turn off the vehicle and when i turn it back on by putting it in gear and popping the clutch(cause im rolling allready) it'll bogg out and when I press the gas it wont go but bogg..i'll start to smell fule then about a minute or two later it'll be fine. If the check engine light comes on and I turn it off and turn it on it'll go away. Im not throwing any codes. Recently when I turn it off when the light comes on it will just crank and crank over and over... The car wont turn over then after like 10 minutes it will start. It seems like its not getting fuel. Its not the fuel filter or pump. Its not my starter nor my cables, plugs, or distr. I've checked it all. I know what i'm doing.
All my wires are connected, from the starter to the plug wires, all grounds are fine. When the check engine light comes on-it doesn't affect the car in anyway.
It doesn't happen all the time. Rarely
Old Jul 10, 2006 | 09:18 AM
da_33's Avatar
Default Re: (6doorsentra)
you could take it apart and look at the main sodder points and see how well they are. Bc I know instead of buying a new one u can re sodder them
Old Jul 10, 2006 | 09:23 AM
I know I can fix it up. The solders actually look fine. I know the littlest space can affect it from working.(space from board and pin)
I'll reheat the solder to make sure its in place but in the meantime i think i'm going to pick one up froma junk yard.. see whats up
Old Jul 11, 2006 | 09:26 PM
da_33's Avatar
i dont know what they will run u from the junkyard but i think mine was $70-80 brand new just so u know incase maybe u pick one up from a junkyard that already maybe needed replacing in the first place
88EFsedan2
Feb 24, 2012 02:38 PM
SaveDaNoob
Jul 7, 2011 07:06 PM
fenix4o9
Mar 26, 2010 05:41 PM
NazVil86
Oct 10, 2006 06:44 PM
EJ1_203
Sep 10, 2006 04:36 PM
