my rex drives like shit
when i full throttle is goes right, when i brake it goes left, there's alot of sounds when i steer coming from the steering wheel parts, when i drive without touching the gas or brake its straight!! whats the problem?
Axels,ball joints, bearings. there is alot that could be the problem, also your tie roads could be done.
EDIT: Try checking your frame it could be broken or have a hella crack in it.
Modified by mitch4x4 at 3:01 PM 7/9/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitch4x4 »</TD></TR><TR><TD CLASS="quote">Axels,ball joints, bearings.
Modified by mitch4x4 at 3:01 PM 7/9/2006</TD></TR></TABLE>
X2
X2
Not to thread jack, but my car is the same. I have all new ball joints, axles, inner and outer tie-rods, LCA bushings.
I don't know where else to go except radius arm and steering rack. Anybody had the same problems?
Had An Accord, that Whenever You Shifted It Jerked Reeeeaaaaal Hard To the Right, and You Had To White Knuckle The Steering Wheel Or It Was All Over. Radius Bar/Bushings Fixed Er' Right Up.
j0keefe21
Feb 5, 2009 04:25 PM
crxaddikt
14
Sep 9, 2005 01:19 PM
