timing belt broke
Old Jul 9, 2006 | 12:43 PM
NikeSB's Avatar
Default timing belt broke
Should I even bother fixing it heard its kinda annoying and I was probably gonna get a shop to do it. I was thinking about a swap anyway so which would be cheaper..the water pump got messed up to
Old Jul 9, 2006 | 01:23 PM
leeminho86's Avatar
Default Re: timing belt broke (NikeSB)
Depends on how much damage was done, if there's a lot of damage and your valves are bent then you'll need a head job. Also keep in mind you will also need the head milled to put the new headgasket on, new coolant, new oil/filter, new timing belt kit, new gasket kit, and shop time to store your car while the machine shop has your head. I got lucky and none of my valves were bent, didn't need a head job, just milled the head, bought all the parts I needed, did all the work myself and it still cost me $400-600. If you're looking at a new valvetrain and having a shop doing it, I'm guessing it would be cheaper to go with a swap. I think the book time for a head gasket alone is 7 hours, so $65 an hour+machine work = not cheap.
Old Jul 9, 2006 | 03:18 PM
NikeSB's Avatar
Default Re: timing belt broke (leeminho86)
Lol dam it does sound like a expensive *** thing a swap would probably be easier but I'm still thinking my engine had mad miles on it anyway
Old Jul 9, 2006 | 04:02 PM
dohcVTECeg2's Avatar
i did mine myself for the first time about 3 years ago. belt snapped but i was lucky also and it didnt expletive up my head. i bought a new belt and hasnt messed up since
Old Jul 9, 2006 | 04:59 PM
NikeSB's Avatar
i dont think anything from head cause i turned my car on it was on for like 5 seconds then just stopped. it was marking my battery so i was like huh? then today my dad said it snapped so i dunno i think a swap would be better
Old Jul 9, 2006 | 06:43 PM
NikeSB's Avatar
i checked it only thing thats messed up is the belt somehow lol im just thinking whats the best way out since my current engine already has about 210k miles
Old Jul 9, 2006 | 07:07 PM
DelSolMarine's Avatar
what kinda motor is in there?
Old Jul 10, 2006 | 04:39 AM
NikeSB's Avatar
Default Re: timing belt broke (DelSolMarine)
stock 94 dx motor i dunno to much about motors yet so i cant really tell you exactly lol so its a b16 i guess.
Old Jul 10, 2006 | 07:02 AM
verycleanhatch's Avatar
i was gonna do mine but i could not get loose the crank pulley bolt.
Old Jul 10, 2006 | 07:09 AM
b16 matt's Avatar
Default Re: timing belt broke (verycleanhatch)
Umm you dont need to remove the crank pulley bolt to do a timing belt.
Old Jul 10, 2006 | 07:18 AM
NikeSB's Avatar
Default Re: timing belt broke (b16 matt)
its stressful but ima just see if i can swap it my dam engine has miles out its ***
Old Jul 10, 2006 | 07:40 AM
dthug's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikeSB &raquo;</TD></TR><TR><TD CLASS="quote">stock 94 dx motor i dunno to much about motors yet so i cant really tell you exactly lol so its a b16 i guess.</TD></TR></TABLE>
its not a b16
get a new timing belt i'll help you out
Old Jul 10, 2006 | 08:28 AM
thehatchninja's Avatar
if it's a DX motor it probably didn't bend any valves. I'm pretty sure it's a non-interference engine. The VTEC motor (z6) will usually bend valves when the belt breaks.
probably a t-belt and water pump would get you back on the road. HOWEVER, if you have the money for an engine swap, now as good a time as ever to do one.
Old Jul 10, 2006 | 08:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16 matt &raquo;</TD></TR><TR><TD CLASS="quote">Umm you dont need to remove the crank pulley bolt to do a timing belt.</TD></TR></TABLE>
then how are you going to get the lower timing cover off?
leeminho86's Avatar
Did you physically take apart the engine and check? The only reason I ask is because we have interference motors and if the timing belt breaks, 99% of the time you will need a head job. Depending on how healthy your motor is if you're looking for an opportunity to do an engine swap now would be as good a time as any, but if you're engine isn't damaged you could buy a timing belt kit for like $100 and just put it on and be good for a while, good luck.
Old Jul 10, 2006 | 08:31 AM
black_EM1's Avatar
Community Builder
Community Influencer
No, it's not a B16. It's most likely a D15, or something, and you're better off just swapping the motor if you have the money
Old Jul 10, 2006 | 09:00 AM
prison_snitch's Avatar
the money spent on timing belt you can get a d16 for like 3-400
Old Jul 10, 2006 | 05:19 PM
NikeSB's Avatar
Default Re: (prison_snitch)
yea a swap would be in my best interest i think since like you are all suggesting the motors health isnt that good 211k miles im already looking into the swap
Old Jul 10, 2006 | 05:27 PM
Sketch_hs's Avatar
Default Re: (thehatchninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote"> I'm pretty sure it's a non-interference engine.</TD></TR></TABLE>
no
also yes you need to pull the crank pulley to do a timing belt
NeilR7
Mar 22, 2014 09:00 AM
stockF22B1
Dec 15, 2012 07:08 PM
1slow02
Sep 30, 2009 10:05 PM
ReactioN
Aug 30, 2008 08:50 PM
95ludeSE_bottle
Mar 23, 2008 11:15 AM
