gauges out except speedo
i have an obdo crx with a b16, and i just replaced my clutch and when i went to go for the first time all my gauges (rpm,e-brake,temp,fuel) went out simeltaneously. i was wondering if this was becuase of a sensor ground, and if so where are the pinouts on a pr3 for all these sensors, and if that isnt it does anybody have any idea of what else it could be and what i need to do to fix it
From: I told you to wait in the truck in Texas, United States
Check your grounds..there is one in particular at the thermostat..
If that is good I would check the fuses for the meter..
EDIT:looks to be fuse #1 in the underdash fuse box
superchi
Oct 26, 2008 03:49 PM
