88-91 d series throttle body options
Old Jul 9, 2006 | 11:51 AM
EFwithS2000taillights's Avatar
Default 88-91 d series throttle body options
Please tell me, if there is any way to put a b18a or a d16z6 TB on a MPFI 90 si manifold. I cannot find a new throttle body, but I have alot of other engines at my house that I can take one off of Or even a d15b vtec TB? please help
Old Jul 9, 2006 | 12:05 PM
pinecone's Avatar
Default Re: 88-91 d series throttle body options (EFwithS2000taillights)
You can use the z6 tb.
Old Jul 9, 2006 | 12:07 PM
really???? you are my hero!! ok so do I have to take anything off of it or put anything on to it?
Old Jul 9, 2006 | 02:25 PM
bump
Old Jul 9, 2006 | 04:13 PM
bump again...I really need this quick..thanx
Old Jul 9, 2006 | 04:55 PM
SIred91's Avatar
Rainman
Default Re: (EFwithS2000taillights)
you can use damn near any honda throttle body-D-H-B-----but keep in mind the location of the IACV on each one, some are different. but they will all work.
Old Jul 9, 2006 | 06:23 PM
d16vtecx's Avatar
Default Re: (SIred91)
obd1 and up throttle bodies have the map sensor on the tb
obd0 have the map on the firewall
Old Jul 9, 2006 | 06:30 PM
boostedblkef's Avatar
Default Re: (d16vtecx)
i got one for a 91 rex si 25 shiped
Old Jul 9, 2006 | 07:45 PM
dr_latino999's Avatar
Default Re: 88-91 d series throttle body options (pinecone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone &raquo;</TD></TR><TR><TD CLASS="quote">You can use the z6 tb.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">you can use damn near any honda throttle body-D-H-B-----but keep in mind the location of the IACV on each one, some are different. but they will all work.</TD></TR></TABLE> Both wrong, let me enlighten you.
Honda has two main flanges for their Throttle bodys for the pertinent motors(D, H, B)
1) The first flange was for the 88-91 MPFI D-Series, this was used for a bit....and then dropped off the face of the world.
2) The second flange sprang to life with the introduction of the B-Series in 1990 and in 92 spread to the D-Series and whenever the H-Series popped up, it spread to that too.
Old Jul 9, 2006 | 08:14 PM
SIred91's Avatar
Rainman
Default Re: 88-91 d series throttle body options (dr_latino999)
so the FAQ at the top of the page is wrong also?
hmmmm.... for missinformation being flung around.
Old Jul 9, 2006 | 08:32 PM
Why do I get more and more confused as paople leave comments?? Mr Latino, I am not understanding what you are saying. Will the d16z6 throttle body fit and work on my 88-91 si mpfi manifold?
Old Jul 9, 2006 | 10:40 PM
bumpity bump
Old Jul 10, 2006 | 02:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFwithS2000taillights &raquo;</TD></TR><TR><TD CLASS="quote">Why do I get more and more confused as paople leave comments?? Mr Latino, I am not understanding what you are saying. Will the d16z6 throttle body fit and work on my 88-91 si mpfi manifold?</TD></TR></TABLE>
Let me break it down further:
[B[THE ONLY[/B] Commonly found throttle bodies that will work on the 88-91 SOHC MPFI intake manifolds are the throttle bodies designed for those manifolds.
Old Jul 10, 2006 | 04:17 AM
nappyroots827's Avatar
Default Re: (dr_latino999)
then how come i used to have a LS throttle body on my manifold, and a z6 throttle body on it now
Old Jul 10, 2006 | 04:21 AM
ludesrv's Avatar
B16A and B18A throttle bodies will bolt onto the manifold. You need to bore out the flange on the intake manifold itself so the B series throttle body can open up 100% with no interference.
Old Jul 10, 2006 | 08:00 AM
what about the d16z6 throttle body?
Old Jul 10, 2006 | 08:05 AM
ludesrv's Avatar
I don't know if it will work. I know the whole IM bolts up, but theres no point to that.
If I were you I'd look for an LS throttle body and port match. If you are going to cam the A6 it will be useful, if you are going to turbo it will be useful aswell. It's useful all around without a tune.
Old Jul 10, 2006 | 08:07 AM
menappi's Avatar
dood why dont u just unbolt the damn nuts and try to put it on....???its more work asking everyone then just trying urself. if it fits it will work, u might have to bore out the hole a bit tho. i know on 92-95 d series that integra throttle bodies will fit cause i have a gsr TB on my z6 intake mani.
alupso
Southeast (Sales)
Oct 11, 2008 05:54 PM
reactiondc2
Jul 17, 2007 09:03 PM
sivikvtec
Dec 16, 2006 05:59 AM
Alchemist80
11
Sep 2, 2006 05:47 PM
civictildeath
10
Nov 22, 2004 09:57 PM
