del sol rear speaker removal
Old Jul 9, 2006 | 10:05 AM
bryphotoguy's Avatar
Default del sol rear speaker removal
Do I remove the protective facplate? Do I have to remove the whole panel?
I tried just shoving a flathead screwdriver to pop is out but it wouldn't budge. I don't want to break it off. Any help??!!
Old Jul 9, 2006 | 10:09 AM
Out of every
Default Re: del sol rear speaker removal (bryphotoguy)
dude you just pop out the middle pannel. then i think i cant remember, but i think you should see 2 screws holding on each inner side of each speaker cover. its really easy after you unscrew them just pull them off they unclip. then you have rear speaker access
Modified by e gee two at 11:30 AM 7/9/2006
Old Jul 9, 2006 | 10:20 AM
Default Re: del sol rear speaker removal (e gee two)
am I going to have to remove the little compartments to remove the middle panel?
Old Jul 9, 2006 | 10:26 AM
Out of every
no i said middle pannel just pull it off. from there trust me you'll know what to do. you dont have to touch the compartments.
just pull off the back panel its just clips.
Old Jul 9, 2006 | 10:29 AM
dohcVTECeg2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two &raquo;</TD></TR><TR><TD CLASS="quote">dude you just pop out the middle pannel. then i think i cant remember, but i think you should see 2 screws holding on each inner side of each speaker cover. just its really easy then after you unscrew them just pull them off they unclip. then you have rear speaker access </TD></TR></TABLE>
thats all you neeed toknow in a nut shell. fairly easy.
ps dont snap the clips or get them stuck in there when you pull
Old Jul 9, 2006 | 02:06 PM
Default Re: del sol rear speaker removal (dohcVTECeg2)
that was easy enough! thanks
ervstr
May 31, 2011 02:57 AM
nthao89
Nov 30, 2008 02:01 PM
phondataz
Mar 30, 2007 07:18 AM
deconstruct
Feb 25, 2005 08:12 AM
deconstruct
Audio / Security / Video
Jun 3, 2004 01:01 PM
