Unplugged hose under hood
Old Jul 9, 2006 | 05:47 AM
nhanimator's Avatar
Default Unplugged hose under hood
I replaced an air intake with OEM parts and noticed that there is a hose that is not connected to anything. (see photo - far left). On the air intake I removed, there was only once place to connect a hose and this other one was already disconnected.
Thanks in advance.
NHAnimator
Old Jul 9, 2006 | 06:51 AM
92ehatch's Avatar
Default Re: Unplugged hose under hood (nhanimator)
i dont know where it goes, but it doesnt look like it goes on the intake tube you have there.
sure that intake is for your engine? possibly look around a little bit more to see if you can find a place for it
Old Jul 9, 2006 | 06:56 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
That intake may not be for that engine. Normally there is another nipple where that hose goes into (a little to the left, and above of the other hose connected to the intake).
http://www.slhondaparts.com/br...=true
Old Jul 9, 2006 | 12:06 PM
nhanimator's Avatar
Default Re: Unplugged hose under hood (tech8)
I'm pretty sure this is good. Pulled it from a 97 in a junk yard and I don't remember seeing more than 1 hose connected to it.
The original part I had in my 95 was a AEM or something like that. One of those H20 suckers. It had only 1 hose nipple as well.
Old Jul 9, 2006 | 01:16 PM
DraKonX's Avatar
I own a 97 Accord EX with the f22b1 and that hose doesn't exist on mine right there. Unless the part it is connected to it put on backwards or something, there are longer hoses on the other side but I don't exactly see how that is possible either. The only two hoses I have coming out of that general area is one that connects to my egr valve and one that connects to a smaller round thing that looks kinda like the egr valve but looks like it has to do with the fuel system which is just to the right of the egr valve. Neither has a metal pipe with rubber hoses on both ends in the middle like that one though.
Old Jul 9, 2006 | 01:17 PM
ForceXVII's Avatar
I think that hose is suppose connected to the smaller air box which should be right next where the air filter at.
Old Jul 9, 2006 | 01:18 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Here are some pics of a 95 EX intake:
I don't think that vacuum hose will cause any major problems. You may have to just plug it. (Someone else may be could chime in on that.)
Old Jul 9, 2006 | 04:47 PM
NormanBates's Avatar
You need a 4 cyl air cleaner tube and the one you took off of the 97 is for a V-6....
Old Jul 10, 2006 | 02:49 PM
nhanimator's Avatar
Default Re: Unplugged hose under hood (KillerAccord)
Assuming that's the case... Thank you very much. Will dig up the correct one.
giantgreenhead
Dec 9, 2007 02:24 PM
95-Accord-EX
Jun 4, 2007 05:56 AM
mugenspoongsr
Jul 1, 2005 08:35 PM
shermanator
Mar 9, 2004 07:31 PM
TeamTooQuick
Mar 30, 2002 06:07 PM
