Oil pressure gauge readin???
Old Jul 8, 2006 | 11:59 PM
DrivinVtec's Avatar
Default Oil pressure gauge readin???
I installed my gauge right at the head. That bolt right next to the vtec seliniod.
Well my problem is that when i step on the gas it jump up an down, which is fine. but when i hold it down around 6k, it jumps way up. 70psi. If i really rev the **** out of it it will go past 80psi. Does this seem right? My old gauge did that but i had a enydn oil pump an they said it was fine. it goes back down after i release the throttle. For some reason i think my old gauge moved faster. can i get some help?
heres a video of whats going on. but i was told its fine for a mech. gauge.Only reved to about 5k
http://s21.photobucket.com/alb...4.flv
also what readings do u have for every day drivin. it seem mine it kind high
Old Jul 9, 2006 | 10:43 AM
MrLude1's Avatar
Default Re: Oil pressure gauge readin??? (DrivinVtec)
That's next to the distributor where the VTEC oil-pressure switch was, right? I was gonna install my Autometer oil pressure sending unit there, but it didn't fit because of the dist. Did you just ground out the line to the ECU?
Old Jul 9, 2006 | 10:58 AM
DrivinVtec's Avatar
Default Re: Oil pressure gauge readin??? (MrLude1)
i just removed the plug that was there. its the screw that has the allen head on it. not the vtec oil pressure unit
Old Jul 9, 2006 | 11:43 AM
92hondalude's Avatar
what size and thread is that hole? i cant find the right adapor to fit it
Old Jul 9, 2006 | 12:17 PM
DrivinVtec's Avatar
Default Re: Oil pressure gauge readin??? (92hondalude)
its a bitch. 1/8 pipe. it was reall tight. we mearured an the thread was 10mm with 1.0 thread. but if u thread some 1/8 pipe in first(slowly)...it will fit. like I said..it was a tight *** fit. but with some typhlon tape it will work like a charm.
Old Jul 9, 2006 | 02:08 PM
PrettyLude's Avatar
how does it affect pressure readings if your getting it through this source, as where you were getting the source from behind the block where the oil pressure sensor is?
Old Jul 9, 2006 | 02:38 PM
DrivinVtec's Avatar
Default Re: (PrettyLude)
it seems to be the same. i asked my buddy what he gets for reading. there the same as mine.
FearDisH22a4
Mar 12, 2009 12:40 PM
boostincoupe
Feb 9, 2006 09:03 AM
PaImportTuner
Aug 13, 2005 11:17 AM
Mario.
Jul 9, 2004 10:27 AM
Pengo
Jun 26, 2002 08:24 AM
