Finished up another manifold the other day...I think I'm getting better... :)
Old Jul 8, 2006 | 11:04 PM
*Boostwerks*'s Avatar
Default Finished up another manifold the other day...I think I'm getting better... :)
Let me know what ya think!
My welds are getting a lot better, and it is taking me FAR less time to finish up a manifold. I hope to have a couple new designs out here soon.
Old Jul 8, 2006 | 11:07 PM
CarTunr22's Avatar
That looks pretty nice IMO. I'd be interested in some critiques because my welding ends up looking very similar.
keep up the good luck
Old Jul 8, 2006 | 11:56 PM
95cxh22a's Avatar
Default Re: (CarTunr22)
nice, i like the gate braces
Old Jul 9, 2006 | 07:59 AM
JDMs1eeper's Avatar
Default Re: Finished up another manifold the other day...I think I'm getting better... :) (Bryson)
lookin great man
Old Jul 9, 2006 | 08:39 AM
CBURKE's Avatar
damn, good job. I can only hope my welds will look like that one day.
Old Jul 9, 2006 | 09:25 AM
weiRtech's Avatar
OG Fabricator
your interior welds almost look better than the exterior!
Old Jul 9, 2006 | 09:32 AM
ManBearPig4silly's Avatar
Looking better. If I may I would suggest trying to keep the filler in the puddle and weaving back and forth in a Z pattern. Kind of a pseudo cup walking pattern. It should help keep the butt welds more consistant and avoid carrying any contamination into the weld with the filler when you dab it.
Interior welds do look better lol.
Old Jul 9, 2006 | 09:36 AM
thermal's Avatar
Beautiful Bryson! Did you make that collector yourself? Keep up the good work
Old Jul 9, 2006 | 09:44 AM
tepid1's Avatar
Default Re: (thermal)
Your right B you are getting much better.... Good job man.
Old Jul 9, 2006 | 10:27 AM
SQ is the SQUAD's Avatar
looks beautiful. keep up the good work and rember to help those just starting out and hopefully we will make less mistakes. and if god forbids it does end up failing, there is no shame in letting us know. alot of us are really here to help and learn. but there are those who are here to hate and hurt, fukk em. good work? what did you use to weld it? how long you been welding?
Old Jul 9, 2006 | 11:12 AM
beak's Avatar
Looks nice... will the external fit? looks like not much room....
Old Jul 9, 2006 | 11:46 AM
erebunicrx's Avatar
does not look bad.. but did you clean the metal before you welded it? also just wondering why the last runner goes way out? but over all not too bad. i know your welds are better then mine (for the time being)
Old Jul 9, 2006 | 01:24 PM
HamiltonRex's Avatar
Default Re: (erebunicrx)
Looks good.. You didnt answer my PM i sent a couple weeks back ?
Old Jul 9, 2006 | 02:45 PM
TurboSI56's Avatar
how many amps were you using?
Old Jul 9, 2006 | 03:54 PM
self_made's Avatar
Default Re: Finished up another manifold the other day...I think I'm getting better... :) (TurboSI56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSI56 &raquo;</TD></TR><TR><TD CLASS="quote">how many amps were you using?</TD></TR></TABLE>
and how many passes?
also, on that 4th runner, is there any reason why you didnt just use one piece of pipe, instead of the 2 welded together?
Old Jul 9, 2006 | 05:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermal &raquo;</TD></TR><TR><TD CLASS="quote">Beautiful Bryson! Did you make that collector yourself? Keep up the good work</TD></TR></TABLE>
It's a BMC collector. I just welded it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">Your right B you are getting much better.... Good job man.</TD></TR></TABLE>
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beak &raquo;</TD></TR><TR><TD CLASS="quote">Looks nice... will the external fit? looks like not much room....</TD></TR></TABLE>
I use a T3/T4 and a 38mm gate to fab up the manifolds...so yeah, it fits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erebunicrx &raquo;</TD></TR><TR><TD CLASS="quote">does not look bad.. but did you clean the metal before you welded it? also just wondering why the last runner goes way out? but over all not too bad. i know your welds are better then mine (for the time being) </TD></TR></TABLE>
Of course. You can see where I sanded the ends. The last runner goes way out in order to avoid the compressor. If you have seen the pics of my personal setup, you can see that the compressor sits right between the #1 and #2 runners.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">Looks good.. You didnt answer my PM i sent a couple weeks back ?</TD></TR></TABLE>
I never got the PM....but I just sent ya one.
90 for the pipe-pipe welds, and 120 for the flange welds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hermsfab.com &raquo;</TD></TR><TR><TD CLASS="quote">
also, on that 4th runner, is there any reason why you didnt just use one piece of pipe, instead of the 2 welded together?</TD></TR></TABLE>
I only made one pass. For that 4th runner, I originally had one piece but I kinda messed up when I welded that runner on. I had it a little offset, so I had to cut it, and reweld it. I won't make that mistake again though.
Old Jul 9, 2006 | 07:45 PM
kordenbrock motorsports's Avatar
looks good, hit that **** with a wire brush dogg it will make it look a lot better. topmount is in our near future too. how close to equal length is this, if at all? keep up the good work. practice makes perfect...
brett
Old Jul 10, 2006 | 06:48 AM
spiceisler's Avatar
Default Re: (kordenbrock motorsports)
Definitely better Bryson! Wire-wheel the pieces before welding, you'll have a more finished-looking piece like this:
Modified by spiceisler at 12:10 PM 7/10/2006
Old Jul 10, 2006 | 10:02 AM
Finest's Avatar
Default Re: (spiceisler)
Looks good.
So how long before you start up "Bry-Fab"?
Old Jul 10, 2006 | 12:57 PM
Default Re: (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">Looks good.
So how long before you start up "Bry-Fab"? </TD></TR></TABLE>
lol.
Well, I should have my website up here shortly. I already have my domain name with all my pictures hosted right now...
http://www.boostwerks.com
Old Jul 11, 2006 | 12:30 AM
ccfab's Avatar
Default Re: (Bryson)
i was gonna be nice, but with garbage like that i think you need to stay the f uck out of my threads and go in your tool shed and keep practicing. noone in their right mind is gonna pay 800 for that piece of ******* ****...
but, have a nice night
Old Jul 11, 2006 | 12:44 AM
Default Re: (ccfab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfab &raquo;</TD></TR><TR><TD CLASS="quote">i was gonna be nice, but with garbage like that i think you need to stay the f uck out of my threads and go in your tool shed and keep practicing. noone in their right mind is gonna pay 800 for that piece of ******* ****...
but, have a nice night </TD></TR></TABLE>
Ahh ok. So thats why I've sold several of them, and get PM'd everyday. Good luck with the shop man.
Old Jul 11, 2006 | 07:40 AM
ccfab's Avatar
well enjoy that while it lasts...
Old Jul 11, 2006 | 07:46 AM
JDMs1eeper's Avatar
Default Re: (ccfab)
hey now, hey now, we're all rocks stars here lol play nice, no need for bashing
Old Jul 11, 2006 | 01:25 PM
civperc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Ahh ok. So thats why I've sold several of them, and get PM'd everyday. Good luck with the shop man. </TD></TR></TABLE>
