EGR Valve? - ECU Code 80: Exhaust Gas Recirculation
Question: Does my Integra have a EGR valve? I have a '97 LS.
My check engine light came on a week or two ago and I took my car to my mechanics house to see what code it was throwing. We got number #80, so we looked it up.
It says its the "Exhaust Gas Recirculation." What the hell does that mean? - He said he never seen that code before.
What do I need to do? Is that bad?
1994-2001 Integra's do not have an EGR valve. So, I'm not sure why you'd be throwing that code.
1990-1993 Integra's, however, do.
maybe...if there were 8 long flashes, then that would definitely indicate 80. No shorter quick flashes?
Interesting...well, if after double-checking that you did pull the code correctly, it might be worth a call to the Honda service garage and tell them you got that code and ask them about it. Of course they may give you a run around and want you to bring it in, but you never know.
Yeah, they were long flashes.
I took it to my mechanics house so he could do the thing to check the code because I didn't know how. After we figured out how many times it flashed, we researched it and found out the code.
He said he's never seen that code before. I searched everywhere. I found code 81, but no 80. He's supposed to find out when he goes back to work on Monday at Honda, so I dunno.
I just wanted to research it because I've been told Integra's and Civic's don't have ERG valves. Only Accord's and Prelude's. I did a search and found this underneath exhaust gas recirculation, "insufficient flow detected".
To tell the truth I'm not understand what this is so I'm just trying to find out.
I think 81-84 is cylinder misfires, right?
Any who, I'm searching to see if I can dig up something on this EGR code mystery..
This is what I used:
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
65 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
Source: http://www.team-integra.net/se...ID=34
0 ECU
1 Oxygen Content
3 Map Sensor
5 Map Sensor
7 Throttle Angle
8 TDC Position
16 Fuel Injector
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
67 Catalyst System
gperry322
Jul 3, 2008 03:53 PM
