1990 Accord A/C R-12 recharge- where do I add it?
Old Jul 8, 2006 | 08:57 PM
rscawley's Avatar
Default 1990 Accord A/C R-12 recharge- where do I add it?
I stocked up on R-12 a while back. Now the system check lens is foamy indicating low refrigerant.
I found a threaded valve behind the radiator at hood level (1/4"?), I found another in front of the firewall, passenger side, which is a smaller thread diameter.
I considered the 134a conversion, but since I have the R-12, and the age of the car, it's easier to top off. Yes, "only a certified technician......blah, blah...". My nieghbor is an HVAC guy so that's covered.
My Haynes manual gives NO detailed instruction, nor does the forum or the web. Where and how do I add it?
Old Jul 8, 2006 | 10:35 PM
v4lu3s's Avatar
RTFM
if your neighbor is the man he should have a clue on which port to add it in....
Old Jul 9, 2006 | 02:47 AM
rscawley's Avatar
Default Re: (v4lu3s)
He's not a car guy, he's busy, I'm busy and I need to get it done. He gave me a guage set to test.
Not the kind of answer I was looking for........I want an education from forum members on an illusive topic.
Old Jul 9, 2006 | 04:19 AM
NAiL05's Avatar
Fill it from the low side of the system.
Old Jul 9, 2006 | 05:33 AM
rscawley's Avatar
Default Re: R-12 recharge?
I am familiar with high and low. Which threaded connection is the "low" side?
Old Jul 10, 2006 | 03:35 PM
crazygangsta301's Avatar
fill the one closest to the radiator fan.
Old Jul 10, 2006 | 03:44 PM
teletekman's Avatar
Default Re: (crazygangsta301)
The High side is usually capped with a Red cap and the Low side is capped with a Blue cap.
Old Jul 10, 2006 | 04:22 PM
Eddiebx's Avatar
the high port is by the firewall, the low port is infront by the radiator
Old Jul 10, 2006 | 05:24 PM
hondadude's Avatar
Default Re: 1990 Accord A/C R-12 recharge- where do I add it? (rscawley)
The small pipe is the high pressure side, the bigger pipe is the low pressure side
hanginbyaccord
Aug 14, 2007 03:27 AM
-RedneckDave-
Jun 18, 2006 09:53 PM
jakeiscool
Nov 29, 2005 06:28 AM
RotaryBzzz
Nov 13, 2002 01:15 PM
