Crankshaft
Hello once again my fellow H-T members. I have a really quick question. Does anyone know if I can use any d series crankshaft on my d16a6 motor, or are the d15/d17/d16z6/d16y8/zc sohc crankshafts different by alil which makes them not interchangeable? My journal got f'd over by spinning a bearing which shreded the surface on one of my journals on my crank. So please, if possible provide advice/info if they are the same or not. Thanks guys!!!!
If I use a d15 crank, and the only difference between the two is a smaller stroke, d15: borexstroke: 75mm x 84.5; d16: borexstroke: 75mmx90mm, all I lose is compression correct? I'm going turbo... so this may help
. Putting a t4 on my car, so any low compression goals would help tremendously. Please give me info!
The stroke is from top to bottom right? The distance it travels? correct? Sorry for the noobish questions, I just started internals like 2 weeks ago. =P
. Putting a t4 on my car, so any low compression goals would help tremendously. Please give me info! The stroke is from top to bottom right? The distance it travels? correct? Sorry for the noobish questions, I just started internals like 2 weeks ago. =P
Smaller main journals? Which we be the journals that are held by the main cap? So the crank spins freely; that one right? Man oh man. Is there concrete information by which you are going by? Can anyone else vouche on his word of advice? Please anyone, help if possible.
Would it be more better if I used a d16a1 crank from an Integra dohc motor? Cuz I can't seem to find other d16a6's in the junk... and I can return the d15 crank for store credit or exchange... So please guys... 411!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaHnAbOi »</TD></TR><TR><TD CLASS="quote">Smaller main journals? Which we be the journals that are held by the main cap? So the crank spins freely; that one right? Man oh man. Is there concrete information by which you are going by? Can anyone else vouche on his word of advice? Please anyone, help if possible.</TD></TR></TABLE>
correct - D15 main journals are 10mm smaller than D16 - HF D15 cranks also have smaller rod journals
Modified by jlicrx at 2:55 PM 7/11/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaHnAbOi »</TD></TR><TR><TD CLASS="quote">Would it be more better if I used a d16a1 crank from an Integra dohc motor? Cuz I can't seem to find other d16a6's in the junk... and I can return the d15 crank for store credit or exchange... So please guys... 411!!!!
</TD></TR></TABLE>yes, D16A1 crank will work - just beware that most D16A1 cranks have the smaller diameter front snout (where the pulley goes on) - some D16A6 and ZC cranks (mostly 88s) also have the smaller snout - just be sure to get the right one
I see. So for sure the crank will fit... but the snouts may vary correct? Thanks jilicrx. Even if the d16a1 / d16a3's are dohcs the crank wouldn't vary much right? Would it be advisable to pull a crank from a 90-91 integra first gen (d16a3 dohc) or from a 88-89 first gen integ (d16a1 dohc)?
Do you think the later model first gen (d16a3) would have the same size snout as my 91 civic (d16a6)?
there are no D16A3s - all 86-89 Integras are D16A1 - 90-91 Integras are B18A1s - most 86-88 Integra D16A1s have the small snout - most 89s have the larger snout, like your 91 D16A6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">there are no D16A3s - all 86-89 Integras are D16A1 - 90-91 Integras are B18A1s - most 86-88 Integra D16A1s have the small snout - most 89s have the larger snout, like your 91 D16A6 </TD></TR></TABLE>
- Correction -
D16A3
* Found in:
o 1988-89 Acura Integra
+ Displacement : 1590 cm3
+ Bore and Stroke : 75 mm X 90 mm
+ Compression : 9.5:1
+ Power : 118 hp @ 6500 rpm & 103 ft·lbf @ 5500 rpm
+ Valvetrain : DOHC
+ Fuel Control : OBD-0
D16A1
* Found in:
o 1986-87 Acura Integra
+ Compression : 9.3:1
+ Power : 113 hp @ 6250 rpm & 99 ft·lbf @ 5500 rpm
+ Valvetrain : DOHC
But yea, I got those numbers/specs from http://en.wikipedia.org/wiki/Honda_D_engine#D16.
Hrm, hopefully I get lucky and find an 89 at the junkie and pull it out. Before anything though, I'm going to measure the diameter and journals (main&rods) and measure the one I pull out from the junkyard... so this way I'm not wasting my time! Thanks though so far jilicrx.
You know what could really help? If you sent me a crankshaft for my d16a6 like a true homie =P
- Correction -
D16A3
* Found in:
+ Valvetrain : DOHC
D16A1
* Found in:
+ Valvetrain : DOHC
Now if I get one with a small snout, then when I put the cap on, on the pulley side, the oil will leak out correct? Anyways, I'll measure and size them up just for my sake. Thanks jilicrx.
- Correction -
D16A3
* Found in:
+ Valvetrain : DOHC
D16A1
* Found in:
+ Valvetrain : DOHC
trust me - that information is completely wrong - there is <U>not</U> a D16A3 - they are all D16A1
- Correction -
D16A3
* Found in:
+ Valvetrain : DOHC
D16A1
* Found in:
+ Valvetrain : DOHC
Looks like I got very lucky today guys... I went to the junk at 7 am this morning... and guess what I saw... a 91 civic hatch si! Complete! *Gasp* I was sooo shocked because for the 4 year span that I've been just going there... I've never seen an Si so.. complete... I have a 91 civic hatch so I was sooo happy. I had to drop the motor... take off the tranny and everything else, and then after 4 hours of labor... in the blistering sun... I got the crank! yes! Happy happy joy joy... Now I'm gonna eat then, get my ******* car running!!!!
