my setup better then JDM type r?? need your opinion
Old Jul 8, 2006 | 08:10 PM
alien's Avatar
Default my setup better then JDM type r?? need your opinion
b18c1 block
pr3 pistions
gsr crank
gsr head
type r tranny
stage 2 skunk 2 cams
skunk 2 cam gears
7 pound flywheel
this guy said the compression of this motor is 12 to 1
would this motor be stronger then a type r motor? and can it run 13.9 in a 99-00 civic Si???
Old Jul 8, 2006 | 08:21 PM
CWTegRNo.160's Avatar
Default Re: my setup better then JDM type r?? need your opinion (sinanovicha)
i'm almost positive this might be a good time to say put on your flame suit, but anyways this might be the wrong forum for you question. Check the all motor forum. In my opinion it seems like you indeed have a better setup if you have the tuning to support your mods. By 13.9 might be pushing it.
But my question is, Is the 99-00 civic Si lighter or heavier than a Type-R? anyone got numbers to support that.
Old Jul 9, 2006 | 02:45 AM
Speed Infliction's Avatar
it would be stronger but not more reliable than the ITR. I also think you can hit 13.9 easily. That is not a hard time to get to. A really good header would do your car wonders with that setup. I am talking around 20whp on top of what you have now. That would be my next mod if I had your setup.
Old Jul 9, 2006 | 07:56 AM
94rs-turbo's Avatar
the si is heavier than the itrs
Old Jul 9, 2006 | 08:25 AM
Reid's Avatar
Global Moderator
You're stupid if you think the ITR's best feature is its engine.
Old Jul 9, 2006 | 08:35 AM
94rs-turbo's Avatar
Default Re: my setup better then JDM type r?? need your opinion (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">You're stupid if you think the ITR's best feature is its engine. </TD></TR></TABLE>
weerd
Old Jul 9, 2006 | 01:47 PM
uNF$@#!'s Avatar
damn. I need to end myself now.
Old Jul 9, 2006 | 08:12 PM
x2
Old Jul 9, 2006 | 08:17 PM
migs's Avatar
Default Re: my setup better then JDM type r?? need your opinion (uNF$@#!)
Your car will hit a high 14. More to it than just. You need tires, suspension and much more to hit your 13.9.
Old Jul 10, 2006 | 02:52 AM
digital sol's Avatar
dont you need aftermarket valve train to run stage 2 cams?
even the with type r head i was told aftermarket valve train is required unless you wanna drop a valve'
Old Jul 10, 2006 | 06:45 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: (digital sol)
How to spec 2's compare with Toda Spec B's?
You can run B's on a stock valvetrain, just keep it out of the rev limiter.
b16_swap
May 28, 2008 11:33 AM
typeRhatchie
Mar 9, 2008 07:49 PM
stoopid_monkey
Jan 28, 2005 09:03 AM
Shea-bird
Jul 7, 2001 12:25 PM
