head question
Old Jul 8, 2006 | 06:58 PM
sparknock's Avatar
Default head question
i have a 91 crx with a motor swap that was done before i bought the car. the wiring for the motor was hacked in to the car. the motor is a 1.5liter bottom end and a 1.6 liter vtech head. how can i identify what year motor the head came off of.
heres a few pics of the car. some one fucked it up really bad and its become my job to unfuck it.
Old Jul 8, 2006 | 09:31 PM
JLefevers's Avatar
Default Re: head question (sparknock)
there is a two digit # stamped on the head mine is on the front but it may vary not to sure hope that helps
Old Jul 8, 2006 | 10:31 PM
SD_Lurker's Avatar
HT White Ops
wow you should ditch those taillights. they previous owner had some bad taste. Other than that the car looks good. There is a stamp on the front of the head right above the exhaust manifold
Old Jul 9, 2006 | 05:29 AM
sparknock's Avatar
i hope so too. thanks any way
Old Jul 9, 2006 | 05:43 AM
kulangot's Avatar
Default Re: (sparknock)
it looks like a 92-95 z6 vtec head ..
Old Jul 9, 2006 | 06:26 AM
sparknock's Avatar
i have a part number off the PCM 37820-p28-a52 the next number is 761-300702 and it has a big AWN on it as well
can some one give me a pin out of what every thing goes to on the PCM?
Old Jul 9, 2006 | 10:28 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
There should be a stamp on the front of the head. As for the ecu pinout...just searh for a p28 pinout in here. There are tons of posts aout it. Good luck man...it sucks having to fix other peoples expletive ups!
Old Jul 9, 2006 | 12:08 PM
C_R_X_V_T_E_C's Avatar
Default Re: (sCeRaXn)
My D15B is from a 92-95 civic, The B16 Head is Most Likely Correct As Posted Above^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^
P.S. The Car Looks Good But Loose Those Disgusting Tail Lights, Its For Your Own Good.
Old Jul 9, 2006 | 03:37 PM
sparknock's Avatar
Default Re: (C_R_X_V_T_E_C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_R_X_V_T_E_C &raquo;</TD></TR><TR><TD CLASS="quote">
P.S. The Car Looks Good But Loose Those Disgusting Tail Lights, Its For Your Own Good.</TD></TR></TABLE>
i have plans to do that. i think there ugly as hell. what is out there to replace them. this is my first honda. i really dont know much about it or the motor. what is the reason for putting a 1.6 head on a 1.5l block besides the v-tec thing?
Old Jul 9, 2006 | 03:45 PM
EnSAn's Avatar
&lt;strike&gt;is there no AIR filter on that? Or did you take it off for the pics?&lt;/strike&gt; Doh! you took it off the valve cover looks like my jdm d15b (no vtech bling on it)
Modified by EnSAn at 4:58 PM 7/9/2006
Old Jul 9, 2006 | 03:55 PM
vegaskurt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparknock &raquo;</TD></TR><TR><TD CLASS="quote">i have a part number off the PCM 37820-p28-a52 the next number is 761-300702 and it has a big AWN on it as well
can some one give me a pin out of what every thing goes to on the PCM?</TD></TR></TABLE>
Looks like its already obd1 Unless you can find the code on the head there is no way of telling. But it looks like a z6 intake so I am gonna say its a z6 head. Not all valve covers said VTEC.
Old Jul 9, 2006 | 04:55 PM
JDM Panda's Avatar
Tail lights:
Theres the Si tail lights with the black trim and say "Crx" in the center Garnish
The hf's are similar but have no trim around them
I like the "CR-X" jdm tail lights they actualy say CR-X on the center Garnish
Theres the "CRX Vtec" tail lights that say CRX VTEC on the Center Garnish
And the Special edition II for the Special edition crxs
I really gatta figure out how to post pics... But These are some of the things you can search for to take a look at, ebay usualy has them.
Old Jul 9, 2006 | 08:42 PM
Default Re: (vegaskurt)
"PCM 37820-p28-a52"
P28 IS THE ECU NUMBER AND THE P28 ECU IS FROM A D15B FROM THE 92-95 CIVICS, AS FOR THE HEAD I WOULD AGREE WITH THE VTEC AS POSTED ABOVE(Z6), ALSO IT MAY BE A Y8???????????????????? I DONT FREAKING KNOW!!!!!!!!!!!!!!!
4f_B_Doc
Northeast (Sales)
19
Nov 10, 2010 05:22 PM
my4thgen
Oct 23, 2007 11:15 AM
EH-3
Jun 19, 2006 09:36 AM
iperez
Jan 22, 2004 03:00 PM
