zc compression test #s
Old Jul 8, 2006 | 06:08 PM
MRN1120's Avatar
Default zc compression test #s
well i did search and since i cant use zc in the search because it needs to be at least 3 letters i got like 1000 threads and i looked through them untill my eyes hurt.well anyway here are my #s
#1 160 #2 150 #3 155 #4 175 what do u think?they should be within 10% of each other right.
Old Jul 8, 2006 | 06:43 PM
CWBETB's Avatar
Default Re: zc compression test #s (MRN1120)
I could be wrong but I thought it was 15-20%. I think I got about 160-170 on mine
Old Jul 8, 2006 | 07:00 PM
Got_soy's Avatar
Default Re: zc compression test #s (CWBETB)
185-sohc
192-dohc
135-service limit
28- max difference
Old Jul 8, 2006 | 07:05 PM
91civicEX's Avatar
lowest has to be at least 75 percent of the highest
so if your highest is 100 ur lowest can be 75
if your highest is 200 ur lowest can be 150
everything in between you need a calculator haha
Old Jul 8, 2006 | 07:27 PM
MRN1120's Avatar
Default Re: zc compression test #s (91civicEX)
so these #s seem to be ok thanx guys
Old Jul 9, 2006 | 04:34 AM
MRN1120's Avatar
anyone else
Old Jul 9, 2006 | 04:51 AM
green91's Avatar
Was the engine hot when you took those numbers?
Old Jul 9, 2006 | 04:56 AM
MRN1120's Avatar
Default Re: (green91)
it was at operating temp. removed all plugs.and unplugged the dizzy. i did not cut off fuel though i should prob. retest with feul cutoff
Old Jul 9, 2006 | 07:37 AM
Lamchop0000's Avatar
Default Re: (MRN1120)
yeah, definately dont test it with the fuel going. pull the ECU fuse.
Old Jul 9, 2006 | 02:17 PM
MRN1120's Avatar
Default Re: (Lam.N)
yeah i just somehow forgot im gonna retest
messeduprex
Jun 28, 2004 10:52 AM
pyro_freak8
Mar 20, 2004 02:05 PM
blah13
Jun 8, 2003 08:18 AM
yoshi234
Feb 19, 2003 12:45 PM
