help: tranny "fill hole" bolt
this is my first time changing the tranny oil on a manual tranny. i cant seem to take the bolt from the fill hole out... WTF!???!
from manual
problem: no space for ratchet
images removed
Modified by PAStA MAAAN at 1:22 PM 3/31/2007
from manual
images removed
it is a very tight fit i had to go buy a smaller socket wrench but then it didnt have enough leverage to crack it open.. i would try using an open ended wrench
From: I told you to wait in the truck in Texas, United States
You need a long six-point wrench..
Cheap tools often produce bad results..
PS>It looks fairly mangled already...
You could also try a long pipe wrench like for plumbing..
If its a d15/16 just loosen the top fill plug and go from the top of the engine bay, you can use a suction gun and just squirt oil right in there, no need to worry about getting your face covered in oil.
Obviously you use the 3/8 ratchet for the drain plug, and a 17mm wrench for the fill.
Modified by mntuner2 at 2:44 PM 7/8/2006
I had my friend pull from the right side and I push really hard from the left side with a boxend wrench. But I usualy refill it from the drain bolt by squeezing the Lucas bottle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joon »</TD></TR><TR><TD CLASS="quote">remove reverse sensor plug and fill up from there. Eassiest way to fill up IMO</TD></TR></TABLE>
ill take a look at that too...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 »</TD></TR><TR><TD CLASS="quote">If its a d15/16 just loosen the top fill plug and go from the top of the engine bay</TD></TR></TABLE>
yea, d15... can u really? any other feedback on this method?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpnucrx »</TD></TR><TR><TD CLASS="quote">just loosen the front bolt (hex) right in the front of the tranny on the topside closest to the radiator and fill....works great!!</TD></TR></TABLE>
dude.. wtf?! wat hex
Unfortunately the hexplug will be under the starter when it is in the car, the speedo hole is drder than pulling the fill plug. If you want pics of how to fill the tranny from the top I can make some. lemmie know soon
It unscrews counter-clockwise with a 19mm wrench..
It has a hex shape right under the black rubber that protects the wires..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZcSI4yA »</TD></TR><TR><TD CLASS="quote">Yeah, just use a combination wrench and use the closed end on the bolt, than kick the wrench with your foot until it gets loose.</TD></TR></TABLE>
yeah agreed. u gotta lay under the car backwards and kick it really hard to snap it loose..
Worse comes to worst, use a set of vice grips, clamp em' on there tight then smack the sh*t outta it with a BFG. I had to do that because of 17+ years of Canadian road salt and cheap tools
. Then replace the bolt with an OEM Honda unit + washer when done
max240
Feb 24, 2004 04:39 PM
