Aftermarket motor mounts?
Old Jul 8, 2006 | 10:16 AM
MadCityLude
Guest
Posts: n/a
Default Aftermarket motor mounts?
I am curious as to what options are out there for complete aftermarket mount kits for the 4th gen H22 lude? If anyone has found any or has any experience with any please let me know!
Thanks
Old Jul 8, 2006 | 10:22 AM
nonvteclude's Avatar
Default Re: Aftermarket motor mounts? (MadCityLude)
i have mine from inovative mounts, they come with the two sides and the rear mount. i know enjo is working on some or they have finished them im not sure. or if you want to go cheap on them you can get the es inserts.
Old Jul 8, 2006 | 11:30 AM
MadCityLude
Guest
Posts: n/a
Default Re: Aftermarket motor mounts? (nonvtechlude)
anyone else?
Old Jul 8, 2006 | 12:33 PM
Hawkze_2.3's Avatar
Innovative is your only option right now. There's nothing else.
Old Jul 8, 2006 | 01:18 PM
bb_one's Avatar
Default Re: Aftermarket motor mounts? (Hawkze_2.3)
How do these mounts compare to stock? Any problems with deleting the front mount, using the Innovative mounts?
Old Jul 8, 2006 | 07:14 PM
Hawkze_2.3's Avatar
Default Re: Aftermarket motor mounts? (bb_one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb_one &raquo;</TD></TR><TR><TD CLASS="quote">How do these mounts compare to stock? Any problems with deleting the front mount, using the Innovative mounts?</TD></TR></TABLE>
Much simpler design and MUCH stronger and stiffer. Fitment is not 100%, though on my set...I had to pry a little bit to get the bolts through.
These mounts are definately strong enough to ditch the front mount.
Old Jul 8, 2006 | 08:18 PM
bb_one's Avatar
Thank you for chiming in, I'll have to look into a set the next time my stock mounts go kaput.
Has anyone else had fitment issues like Hawkze?
Old Jul 9, 2006 | 01:55 PM
yOnKiNaToR's Avatar
fill them with polyurethane costs $5-10
Old Jul 9, 2006 | 02:12 PM
Bee18see's Avatar
hasport is better
Old Jul 9, 2006 | 03:02 PM
98vtec's Avatar
moderator emeritus
Default Re: (Bee18see)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bee18see &raquo;</TD></TR><TR><TD CLASS="quote">hasport is better</TD></TR></TABLE>
if you knew anything, you would know that hasport doesnt have any for the lude. Now go back to school.
Old Jul 9, 2006 | 03:47 PM
team123luder's Avatar
Anyone willing to make some H22 mounts for a 3rd gen?
Old Jul 9, 2006 | 04:57 PM
HybridBB6's Avatar
Default Re: (team123luder)
Do you think those Mounts would work on a 5th gen?
Old Jul 9, 2006 | 05:01 PM
Hawkze_2.3's Avatar
Read you moron.
Old Jul 10, 2006 | 11:14 AM
MikeLuder's Avatar
I'v got innovative mounts on my 4th gen! They are the only mounts available for our ludes right now, but worth it. Much stronger and eliminates the front mount. I had a bit of fitment issues because I have a Jdm swap. Tranny mount needed to tap new holes. usdm models should fit no problems. This is one mod that is by far worth paying for.
My girl likes it when my motor is stiff.....lol
Innovative Mounts
Old Jul 10, 2006 | 11:18 AM
petern101's Avatar
Default Re: Aftermarket motor mounts? (MikeLuder)
^aww is that why ppl have fitment problems?
garn (another member) had them and said the fitment was horrible. something about a crossmember hole.
anyways, heard good things about innovative. you can always make your own mounts, buy some new oem mounts and fill in with polyurethane.
but other than that, there are few options for preludes
Old Jul 10, 2006 | 11:25 AM
bb_one's Avatar
Default Re: Aftermarket motor mounts? (petern101)
Do the poly inserts actually have a big affect on reducing engine movement?
I also have a JDM h22 and would rather not deal with making new holes on something that I would be paying close to 300 for.
Old Jul 10, 2006 | 01:24 PM
MikeLuder's Avatar
on the JDM trannys you need to tap new holes in the tranny, not the mounts themselves. This was actually not to difficult however I had the tranny already out, as I was puttin in a new clutch. But like i said, they are the only available for the prelude and so far I love them. Real firm stiffness with not too much vibration.
Innovative
Without the front mount, im looking to do a nice custom turbo setup.
Old Jul 10, 2006 | 02:15 PM
soundbomber's Avatar
i didn't know there was a difference in the usdm/jdm tranny bracket?
looking to get some innovatives soon, but still kinda holding out for someone to answer my prayers and make something out of some billet.
Old Jul 10, 2006 | 06:03 PM
esedulerp5tenin's Avatar
Default Re: Aftermarket motor mounts? (soundbomber)
http://www.passwordjdm.com/pro...D=467 says "Replacement Mount Kit for 1992-1996 BB4 Preludes. Designed to fit all H and F-series motors."
so does this mean they WILL or will NOT fit H23's??
Old Jul 10, 2006 | 06:41 PM
petern101's Avatar
Default Re: Aftermarket motor mounts? (esedulerp5tenin)
^well an h23 is part of the h series
so yeah dude, it will fit.
Old Jul 12, 2006 | 05:44 AM
what is required to install motor mounts??
do you need an engine lift?
Old Jul 12, 2006 | 05:46 AM
no, u just need a jack to support the weight of the motor
Old Jul 12, 2006 | 08:03 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">Designed to fit all H and F-series motors."
so does this mean they WILL or will NOT fit H23's??</TD></TR></TABLE>
It says it will fit all H series engines....you used the 'H' key on your keyboard when you typed H23 so yes, it will work.
Old Jul 12, 2006 | 08:33 AM
for some reason i thought BB4 meant only H22's, thats why i was confused. oops.
Old Jul 25, 2006 | 10:30 PM
kartoon529's Avatar
is the raeson my car shakes at like 60(recenly started) the motor mounts?someone said i needed a mount job! im a female learning so...........and what gen is my prelude its a 92 s series w/ f22b??? thx guys
