bruning oil
Old Jul 7, 2006 | 08:30 PM
Singlecam4dr's Avatar
Default bruning oil
d15b2 there is oil in cyl. 3 and 2 just replaced the valve cover gasget seals and all still there WTF help plzzzzzzz
Old Jul 7, 2006 | 08:37 PM
nappyroots827's Avatar
Default Re: bruning oil (Redneck_civ)
check your compression just incase, probably isn't your problem, most likely its gonna be your valve stem seals, im assuming you haven't done them...?
Old Jul 7, 2006 | 08:39 PM
Default Re: bruning oil (nappyroots827)
is that pretty easy to do like in one hour er so
Old Jul 7, 2006 | 08:41 PM
nope, gotta take the head off, it can be done in like 4 hours, but your gonne need to replace the head gasket, and your intake and exhaust gasket are probably shitty if there old...so you might as well just buy a head gasket set and rebuild the head, probably worth it...
Old Jul 7, 2006 | 08:45 PM
alright thanks but **** i meant oilin the spark plug tube hole not cly srry bout that and ideas now???
Old Jul 7, 2006 | 08:47 PM
oh, ive replace my spark plug tube seals on mine and it still does it on one cylinder, i just deal with it, try a little sealant on the tube seals, might help...
Old Jul 7, 2006 | 08:49 PM
already did but thanks what u got ie car and engine
Acura_DreamiN
Oct 26, 2010 07:23 PM
jdm mini me
10
Mar 25, 2010 09:04 PM
TunesEK
Jan 15, 2009 01:35 PM
Dorksk8tr3
Aug 18, 2005 09:46 AM
USDMMARK
11
Oct 1, 2003 07:22 PM
