Semi Rebuilt my GSR motor
Old Jul 7, 2006 | 06:06 PM
HGL1668's Avatar
Default Semi Rebuilt my GSR motor
Hello, just looking for some susjestions.
My motor has 52,xxx miles and decide to do the following
Jun 3 Cams
Toda camgears
Toda Valve Springs
Toda Retainers
Civic Type R pistons
Toda timing belt
Apexi Power FC tune
Fuel Regulator and guage (Don't know what brand I should get)
Do I need to upgrade water pump and fuel filter?
if so, what brand, OEM?
How about Oil Pump gears
I also want to get the Skunk2 intake manifold and some TB, what size and brand TB should I get.
Any other maintains stuff I should do while I am at it?
How does the setup look?
Old Jul 7, 2006 | 06:11 PM
lVlemphizStylez's Avatar
Default Re: Semi Rebuilt my GSR motor (HGL1668)
why the apexi pfc? those things are overpriced and there are other cheaper just as capable even better alternatives
Old Jul 8, 2006 | 09:19 AM
HGL1668's Avatar
my tuner had good result with them, better than the hondata
Old Jul 8, 2006 | 11:21 AM
HGL1668's Avatar
bump
Old Jul 8, 2006 | 11:43 AM
DC2 Mang's Avatar
the OEM water and oil pumps will be fine for your motor
as for the manifold and TB, I would go with a skunk2 port matched and bored at the inlet to 70mm
get a 68 to 70mm TB of yor choice and you will be fine, and make some pretty decent power gains
I would also upgrade to some RC 310cc injectors to make the maximum power out of the motor
Old Jul 8, 2006 | 12:12 PM
HGL1668's Avatar
Default Re: Semi Rebuilt my GSR motor (DC2 Mang)
thanks for the advice, bump
Old Jul 12, 2006 | 05:45 PM
HGL1668's Avatar
I am actually thinking about getting Arias Pistons, because I want to running the motor with no problem for a long time, In socal, there is only 91 octane for pump gas, Should I get 11.9, 12.2, or 12.5, If I am running the Jun Type III cams, I want get most of the power out of the cams while running it safe. Any advise are welcome
HaNgTiZZy
May 9, 2009 09:16 AM
Seminole
10
Mar 11, 2008 09:01 PM
The Tea-father
39
Feb 24, 2005 05:04 PM
mikes98typer
Jul 27, 2004 05:44 AM
whitemike5
Jan 15, 2003 02:53 PM
