very Low compression
Old Jul 7, 2006 | 02:59 PM
kuklovod's Avatar
Default very Low compression
Hi ,there! Please help!
I just had mu timing belt and water pump changed on my honda civic 1994 DX and the compression dropped a lot.Tha mechanic told me it should build up pressure as I drive it.The acceleration is really slow.I almost got into an accident after I tried to turn on an intersection and stepped really hard on the gas but it took 5-6 sec. to accelerate slowly.Is this normal or there is something wrong.i told the mechanic if it doesn't get better I will bring it back there.It sucks.i just spent over $1500 for a distributor,timing belt and water pump change.It ran perfectly until it just couldn't start one day.
If you have any suggestions or advises i will greatly appreciate any advice.
Thank you!
Old Jul 7, 2006 | 03:03 PM
Slamaccord's Avatar
Default Re: very Low compression (kuklovod)
I'll put money on that the timing belt is off a tooth.
Bring back to that guy and have him take a look at it.
Old Jul 7, 2006 | 07:15 PM
project_delta's Avatar
Default Re: very Low compression (Slamaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord &raquo;</TD></TR><TR><TD CLASS="quote">I'll put money on that the timing belt is off a tooth.
Bring back to that guy and have him take a look at it.</TD></TR></TABLE>
Better still, take it to someone else! If a mechanic doesn't know how to properly replace a timing belt, then I would take it to someone else that does! Definetly sounds like it's off a tooth though, yeah.
Old Jul 7, 2006 | 10:53 PM
40mpgEK's Avatar
I've never worked on a honda engine (except the B18C i just tore apart), but if they changed the distributor and timing belt, it sounds like the timing is really retarded. I'll second the timing belt being off a tooth.
Dont take it back to the mechanic. Nothing inside the engine would cause it to "build compression" as you drive it. Thats a cop out answer and is the mark of a horrible mechanic.
mejim707
Aug 26, 2008 08:36 AM
MISFITofMAGIC
Jan 7, 2006 08:53 PM
Iomega01
Aug 2, 2005 08:12 PM
ham
Nov 16, 2004 04:49 PM
94SuperLudeSI
Feb 8, 2004 08:36 AM
