Sunroof wont open.
93 civic coupe si
sunroof jiggles slightly but wont open, Tilt or full open) motor is working as i can see it trying to pop the glass, but then it hits a brick wall.
any ideas?
should i manually force it thru the hand crank hole?
any ideas?
mine kinda does this, it goes up a little bit but then stops. if u push up on the rear part of it with a little force and hold the switch it should pop up and open. i think i found the source of my problem tho, im missing a special bolt that bolts the glass to the track and its causing it to open a little off centered...
mvp4unc
Apr 17, 2017 08:01 AM
LOABA
Apr 20, 2006 11:40 AM
