AC Turns on out of no where while driving?
I have a 00 Gsr and the AC keeps truning on out of nowhere. I will be sitting at a light and it will just turn on. It sounds as if it turns on only when the Radiotor fans turn on after the Radiator relay kicks in. Any reason as to why its doing this? How can I stop it without having to disconnect my ac?
yes my switch Is off and pushed out and not illuminated, I feel it turn on because when Im driving the car just gets slugish as it would when I normally turn the AC on ( by pressing the AC button), so I know the button is working fine cause it turns on the ac when pushed in and turns off when pushed out. Also I did a test I left my cabin fans on 3 and with the AC button off and the air was basically the outside temperature as it would be with no AC. Then out of no where I feel the air get as cold as it would be if the AC was on. It seems to only turn on when the radiator fans turn on after the thermostat turns them on.
