Gen 2 Integra rewire
pain in the *** huh?i figured it was just unplug and reaplace but i was just seeing if i needed to know anything else before i start messing with everything thanks bro
well you have to take off the dash. you also have to take off the heater core and a/c evap you also have to take out the fuse box / battery tray also if your car has abs you have to trace the wires under the motor and i believe the firewall harness connects to the passenger headlight. ummmm... yeah its one hell of a pain in the ***. i had to replace mine cause my car is a theft recovery and they cut the cluster wires and ecu wires. i hope this helps a little more but yeah everything has a plug so you just unplug it. you will also have to be kinda careful about all the clips that fasten the harness to stuff, they break easy
