need some help 6th gen 98 ex
i had takeing my car to hook ups to do a 5speed swap i get there and they say that because my accord is a 98 ex that it harded to do it and that the ecu needs some kind of code for the ecu that may or may not work so has any one done this swap on this year if so let me know so maybe you can help me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm-fo-life »</TD></TR><TR><TD CLASS="quote">they say that because my accord is a 98 ex that it harded to do it and that the ecu needs some kind of code for the ecu that may or may not work </TD></TR></TABLE>
the 98s have an immobilizer which checks the code for the key against the code programmed in the immobilizer unit.
I've heard varying answers whether or not the immobilizer is actually inside the ECU itself. If it is you will have to have the ECU reprogrammed to match the key (or the key to the ECU). The dealership is the only place I know that can do this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">at the min you will 5spd, VSS for 5Spd, and driveshafts with abs rings (if you have abs)</TD></TR></TABLE>
and the 5 speed ECU.
blacktibby07
Mar 7, 2011 04:16 PM
