Fuel and coolant temp sensors are not working.. what could be the cause?
i should have said.. fuel and coolant temp gauges are not working
as soon as i hit III it jumps to hot.
Already tried a different cluster and same exact thing.. so.. what could be the problem? all wiring is in tact.. car runs, starts...
it might be stupid question but
do you have the right sensors hooked up to your block?
why dont you check that out first and maybe measure the voltage to that connector and see if you get any power to it.
puertoricanboy90
Jan 28, 2009 02:35 PM
puertoricanboy90
Jan 28, 2009 10:03 AM
DOHCarp
Sep 19, 2003 09:35 AM
