Power Steering on a B18B DA, HELP!
Old Jul 7, 2006 | 09:51 AM
SIRIUS EJ8's Avatar
Default Power Steering on a B18B DA, HELP!
Hello Tech-ers,
I have a question concerning my DA with a b18b swap. My B18B doesn't have powr steering. What parts would i need in order to put the power steering back into my car, Do i need anything Aside from the Power Steering Pump?
Old Jul 7, 2006 | 12:35 PM
i-VTEC_do_you's Avatar
Default Re: Power Steering on a B18B DA, HELP! (96toSi)
step:1 check to see if the original da powersteering pump fits the b18b brackets
(I don't think they are the same)
step2: But if they are bolt it up and check to see if the PS pulley and the crank pulley line up
(again I don't think they will but I never tryed)
step:3 If they line up, match a belt and you should be good to go
step:4 Now if the pump doesn't fit the b18b bracket see if the original da PS brackets fit
(also don't think they will fit)
step:5 if they do your good to go back to step:2 and keep checking everything
Old Jul 7, 2006 | 08:37 PM
Kyoto now's Avatar
Default Re: Power Steering on a B18B DA, HELP! (i-VTEC_do_you)
You'll need the pump, Resevior, Pressure hose, return line, and if you've been driving around without power steering for a while, probably a new rack. I have a B18B in my 91 DA and all the original brackets work perfectly. Good Luck!
Old Jul 8, 2006 | 12:16 AM
SIRIUS EJ8's Avatar
Thanks fella's you are of big help.
Kidnkorner
Dec 16, 2009 04:11 PM
nuckingfuts
Jul 6, 2004 05:44 PM
PUSHER
May 9, 2003 07:36 PM
streetspeed
10
Apr 9, 2003 04:53 AM
Turbo Powa
Dec 16, 2002 01:33 PM
