2001 cr-v k motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadreams »</TD></TR><TR><TD CLASS="quote">if i take a 2001 cr-v k motor an put rsx intrunals would it have the same out put</TD></TR></TABLE>
That won't work. The CRV K24 has an 87mm bore and a 99mm stroke. The RSX K20 has an 86mm bore and 86mm stroke. The best thing to do would be use an RSX-S head on the K24 block. That would give you similar HP numbers and more TQ.
http://www.k20a.org
http://www.k20a.org
