Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
brakes and pads for a dd/autox/hpde car (i tried searching)
Old Jul 6, 2006 | 06:12 PM
rockdude14's Avatar
Default brakes and pads for a dd/autox/hpde car (i tried searching)
sorry i know there are topics on this i tried searching and got 4 results that didnt have anything to do with this
if theres a good thread and you can post it ill read it
my car is a daily driver an autoxer and a hpde car all in one
when i ran at mid ohio for my first hpde with my 01 integra gsr i noticed some fade at the end of the 20 minute sessions but on one braking spot at the end of the long straight i noticed it was significantly worse and my instructer said it might be a little debris building on the discs (not sure what would help with this)
i havent noticed any problems in autox's or daily driving
im thinking of getting brembo blanks and if i remember correctly from other thread that hawk hp plus in the front and hawk hps in the back
any advice on this would be great
thanks
Old Jul 6, 2006 | 07:39 PM
chrisw85's Avatar
if you can still find a set, cobalt friction GT Sports would be better than the HP+ in my opinion.
I would suggest the carbotech panther+ as a dual purpose pad, but! they make a lot of noise on the streets, moreso than the milder bobcats, and more noise than the GTSports from cobalt.
so id suggest in this order for noise: gt sports, hp+, bobcats, panther+
for performance dual purpose: panther+, gt sports, hp+, bobcats.
but ideally you should seriously consider getting purpose pads and swapping them out as need be.
Old Jul 7, 2006 | 10:44 AM
rmcdaniels's Avatar
Default Re: brakes and pads for a dd/autox/hpde car (rockdude14)
I've had a good experience with EBC Yellow Stuff-R pads on generic rotors that I had cryo-treated. Two events and a few thousand miles of daily driving and everything looks like new. They work well too, I was trying to cook them last time I went to VIR, braking harder and later than usual, and had no problems with them. Cold bite is not the best, but it's very manageable and easy to daily drive. I've heard good things about the Cobalt GT Sports too, but never used them.
Old Jul 7, 2006 | 12:10 PM
MaddMatt's Avatar
Default Re: brakes and pads for a dd/autox/hpde car (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">but ideally you should seriously consider getting purpose pads and swapping them out as need be.
This would be my recommendation. And I have nothing positive to say about any EBC product....
Old Jul 7, 2006 | 04:10 PM
rockdude14's Avatar
Default Re: brakes and pads for a dd/autox/hpde car (MaddMatt)
i have single purpuse wheels and tires
adjustable suspension parts
i guess it makes sense to pick a break pad for each purpose.
ok well i guess ill get a brake pad for daily driving and autocrossing
and than one for track days
any recomendation on each set?
thanks
Old Jul 7, 2006 | 07:54 PM
vietnameeh's Avatar
i use stock for DD ... lifetime autozone
then... i might dip into the cobalt pads for track use.... i have tried HP+ but no enough for me and my noob foot lol
Old Jul 9, 2006 | 02:36 PM
milano98gsr's Avatar
Default Re: (vietnameeh)
I've had great results with HP+ front and rear for combination daily/HPDE use. They do make a good bit of dust relative to Autozone lifers, but a good compromise. Biggest factor for me for fade on the track was fresh, high quality racing grade fluid. I used to swap them out for HPS between events, but the car is now primarily for track work, so I don't go through the trouble anymore...
Old Jul 10, 2006 | 09:27 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockdude14 &raquo;</TD></TR><TR><TD CLASS="quote">when i ran at mid ohio for my first hpde with my 01 integra gsr i noticed some fade at the end of the 20 minute sessions</TD></TR></TABLE>
Did this happen during the entire event, or just the first session or two?
Many brake pads exhibit "green pad syndrome", in which they fade (big time) the first time they get up to the really hot temperatures on the track. First session, sometimes second session too. Then they're fine for the remaining life of the pad.
Old Jul 10, 2006 | 09:56 AM
rockdude14's Avatar
Default Re: brakes and pads for a dd/autox/hpde car (nsxtasy)
wow nice catch
yes it was during the first session
it seemed pretty bad but it was never that bad again
my instructer recomened cobalts thats what he used on his ITR
so I might use those for HPDE's
and hp+ for street and autox (dont care about brake dust)
thanks for the help
92integraVTECgsr
14
Jul 17, 2013 11:52 AM
Lo-Buck EF
15
Sep 15, 2003 06:22 AM
BeerMan
May 25, 2003 01:21 PM
yoshi234
10
Mar 27, 2002 11:18 AM
tegtyper
Jun 20, 2001 12:38 PM
