how to run wires for crx fog lights
alright so i just put fogs on my 91 and i got the stock fog light switch, and now i need to know how i should be running the wires... i searched but im sure i probably did not search well enough... so how do i run the wires for the fog lights?
and while im asking my lower turn signals do not work either how do i run this wire? and my outer most turn signal or w/e signal that would be does not work...
i do not care weather my fogs are hooked up to the high beams or not as long as there hooked to the switch. im not sure if the fog switch comes stock how mine is but it has 3 prongs on the back of it.
you should have to hook them up to your high or low beams just as long as you have a power source, the way the switch should work is it should have 3 pins in the back for wires, one should be a ground the other should the power and the other should run to you fog lights, there may be a additional pin if its an adjustable switch
JDMJUNKIEMONKIE
Oct 25, 2009 02:17 AM
jordan_civic
May 19, 2008 09:21 PM
95ej1
22
Mar 6, 2005 04:00 PM
bigedx
Jan 1, 2004 02:01 PM
