main relay symptoms but its brand new.. what else could it be?
ok i think im either haveing some ground or power issue's
i have symptoms like a bad main relay but i know thats not the problem, i just replaced mine with a brand new one from honda that i bought yesterday
my injectors arent fireing, ecu isnt seeing power, and fuel pump isnt primeing
earlier i had a check engine light and now i dont get one at all.. the main relay buzz's instead of clicking like it should and im kinda stumped on what to check
anyone know anything that could cause symptoms like this other then a main relay?
what did you do? did you did a motor swap or smoething...??what the car running before it happen??.......well last time that happen to me what when i rebuild my motor...and i forgot the ground where the thermostat housing is at. check right there...
i just rebuilt my Z6 for bigger boost.. i may have forgot that ground though, i was putting the last bits together on 3 hours of sleep, lol... thanks for the tip
we had the same exact problem. it turned out being a bad ground. between the ecu and the water neck thermostat ground. to test it, we took all the grounds for the ecu and re-grounded them right to the chassis. car fired right up.
hope it helps.
hope it helps.
well the thermo ground wasnt hooked up, so i hooked it up, and still the same problem
anyone got a good place to ground it to without extending the wire?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WolfGod »</TD></TR><TR><TD CLASS="quote">got it workin.. just gotta dial in the timeing and she'll be done
What was the problem?
</TD></TR></TABLE>What was the problem?
wignersfriend
Oct 1, 2005 05:20 PM
kolumbus4
Jul 8, 2004 12:45 PM
