stupid questions but.......
Okay, I'm about to do a regular routine tune up on my b16 swapped hatch, and I'm not sure what distributor cap and rotor to use, and also I'm going to need to replace the clutch fairly soon.... and I'm not sure what clutch to use....... on the Clutch I'm assuming that I can use a clutch made for the del sol or civic si... and I think that the cap and rotor will also be from the del sol , or civic si... am I correct? any info would be a helpful thanks
1990 integra for the cap and rotor
1990 integra for the clutch
When ever you buy something for the del sol, you really have to make sure its the dohc engine. A lot of parts stores only have the sohc in the file, they have to look it up separately. Ask me how I know this
, if I have to ask for a part I just use the 2000 si , or the 90 integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">1990 integra for the cap and rotor
, if I have to ask for a part I just use the 2000 si , or the 90 integra.</TD></TR></TABLE>
True alot of those parts guys give me sohc components...Its very annoying especially when you repeat yourself 100 times that it has to be DOHC 1.6L...
Ill add you can use the 88-91 civic/crx cap and rotor for the obd0 b16..For clutch use 90 integra if its a 90-91 tranny,,but if 92-93 tranny get the 92-93 integra clutch
, if I have to ask for a part I just use the 2000 si , or the 90 integra.</TD></TR></TABLE>True alot of those parts guys give me sohc components...Its very annoying especially when you repeat yourself 100 times that it has to be DOHC 1.6L...
grlracer97
May 5, 2005 09:48 PM
civictech22
Aug 17, 2004 03:49 PM
