Is the ignition control module linked to the starter somehow?
Old Jul 6, 2006 | 01:23 PM
wambus's Avatar
Default Is the ignition control module linked to the starter somehow?
My son has a '95 Civic vtech. The car exhibits symptoms of a bad ignition control module. Won't start after it has been recently running or won't start when very hot. Odd thing is that the starter does not turn over. We have replaced the starter. We have replaced the main relay. He used to have an Accord - when the module went bad the car still turned over.....
Can anyone help?
Old Oct 2, 2006 | 11:26 AM
sitinthehall's Avatar
Default Re: Is the ignition control module linked to the starter somehow? (wambus)
I am having a similar problem. Did you ever get this fixed? I need to know for myself before I go randomly replacing things again...
Old Oct 2, 2006 | 11:28 AM
Luserkid's Avatar
Default Re: Is the ignition control module linked to the starter somehow? (sitinthehall)
If the starter doesnt turn itself and it checks out good when tested then look at the starter safty switch (manuals) and make sure the line is good and also check the power line.
lkx
Sep 14, 2011 11:14 PM
battleREADYb20
Apr 30, 2009 02:36 AM
ednyc
May 23, 2008 08:24 PM
EG6-SIRII
Jan 12, 2007 01:50 PM
RUBZERK
Sep 18, 2004 05:13 AM
